1020 Hydraulics; can remotes be added?
Ryan S.
08-02-2004 22:26:12
I'm buying a 1966 JD 1020 (still have to go pick it up), and by all accounts on these discussion boards it's a pretty solid machine. My question is this. There are no hydraulic remotes on the rear. Is it possible to add them and if so what's invloved. This is my first tractor so any other info anyone wants to give me about this model would be greatly appreciated. - Thanks
Jim B
08-03-2004 04:16:10
 Re: 1020 Hydraulics; can remotes be added? in reply to Ryan S., 08-02-2004 22:26:12
Ryan,yes remote valve can be added to JD 1020.To put factory valve on takes some time and money.You could check salvage yards.You have to put a fitting in priority valve on RH side under floorboard and run line up to valve.If you can't find factory valve and scv's you can plumb in a CLOSED CENTER valve.I have seen them mounted on fender if you don't mind drilling holes in fender or build a bracket that bolts to axle.The oil return is a plug on RH side of rockshaft housing.Jim B
Ryan S.
08-12-2004 03:32:37
 Re: 1020 Hydraulics; can remotes be added? in reply to Jim B, 08-03-2004 04:16:10
Jim B - Thanks for the help. I think I have located the necessary Deere parts to do this job (a little pricey, but it will keep things original). I have a question about your follow-up. I don't understand what I need to install under the right floor board. Do I just thread in some type of hyrauclic fitting or is there another valve of some sort that has to go there before I run a line to the SCV?
The parts that I have located include the selective control valve (with control lever still attached), mounting plate, and a set of aftermarket couplers that will mount to the rear end. Aside from the 4 hoses needed to hook everything together is there anything else I will need to get this job done?
Thanks in advance for all of your help (sorry if the these questions are simple, but this is new to me).
Ryan S.
Ryan S.
08-05-2004 00:13:47
Jim B.
Thank you so much for the answer to this question. I'm going to do a little searching for the original parts, and if they don't turn up, your "closed center valve" option will work just fine. I can't wait to get this great little tractor home and start doing so updating on her!
Thanks again,
Ryan S.
