4630 wheels hubs
Charlie
08-02-2004 20:25:30
recently I moved the wheels in on the axel, since this time i can't seem to keep them from moving in or out. any ideas
Mark
08-03-2004 15:01:32
 Re: 4630 wheels hubs in reply to Charlie, 08-02-2004 20:25:30
Those hub bolts need to be torqued to 300 ft.lbs.
Wayne
08-03-2004 06:50:52
You also want to check and make sure that the half with the key in it that the 3 bolts tighten up is not worn. I have seen the key way get worn and it will not tighten up either.
msb
08-02-2004 20:48:34
Are you sure you have the two jackscrews backed all the way out?That is usually the cause of the wheels "traveling".If they are, put a 4' pipe on a breaker bar and socket and LAY into it.
Charlie
08-03-2004 04:42:50
 Re: 4630 wheels hubs in reply to msb, 08-02-2004 20:48:34
thanks for your idea, i'ved tried a 8' pipe before
Heat Houser
08-02-2004 20:37:37
Did the same on my tractor. Kept after them with the cheater pipe, both inners and outers till they stayed tight. Every couple of hours I tightened the six bolts and finally on day two, success. Inner wedge"s flange needs to be tight against the wheel hub. The outer wedge does the "tightening".
