4010 deere
ron b
08-02-2004 20:12:21
baling hay when tractor started making loud hydraulic noises under seat. would get worse when idled down. hydraulics began to operate slower and for some reason tractor would stall. after finially getting it started i headed for the house and tractor stalled out again, like it was in a strain. finially started again and ran fine till i reached destination and when idled down it started making grinding noises under the seat and stalled again like the engine was locking up. to make a long story short i did go back out the next day and baled around 50 more bales. as long as it was idled up it was reasonably quiet. i finially took the rockshaft housing off and replaced a bad tranny pump and after thinking i would replace the top tranny shaft bearing in place,(MISTAKE) and screwing it up, had to split the tractor and pull the whole shaft out. the shaft got damaged and i found a used one complete and reinstalled, took a dial indicator and set the end play at .005 like the book said. after assembly i started the tractor and things were quiet till the hydraulics picked up, then came that same noise though not near as loud. i did bleed the brakes, hoping that would get rid of it. i cut about 15 acres of hay and it got lots better but still when i park it and idle all the way down, the noise is there and when i pull the kill switch, the engine stops suddenly instead of coasting down. i may have to live with it but it is not the same as it used to be. i would appreciate any input on this. i did forget to mention that i forgot to install the new o rings on the pipe tubes that go to the trans. pump. the old ones are still on them. thanks.....
msb
08-02-2004 20:54:47
 Re: 4010 deere in reply to ron b, 08-02-2004 20:12:21
Did you remove all the gears on the top shaft and have a look at them? That transmission pump supplies lubrication to the top shaft and is the only lubrication it gets.Sounds like you have some gears that are trying to marry up with the top shaft,NOT GOOD!Hope I am wrong!
ronb
08-04-2004 00:31:32
 Re: 4010 deere followup in reply to msb, 08-02-2004 20:54:47
baled hay again today. tractor ran good. still at low idle i have that noise. tried different things such as holding clutch in. noise still there. sitting still. same. it runs quiet at just above idle and on up to full throttle. yes, i did check the gear train on the shaft when new bearings were installed. i did notice one thing today. i crawled under the front end to take a look at the hydraulic pump coupling and saw that it is driving by only one side. it looks like one of the bolts has broken out of the hub that connects to the crankshaft. i dont know for sure but it could be where this noise is transferring from. im going to take it apart tomorrow and start repairs. sure would be nice if that happens to be the problem. thanks for your reply.
