Cdavis, you ask... Quote: "replaced brass bushing and bearings in the clutch assembly. New brass bushing is not rolled over like the old one, should it be?" ..... Answ, Deere is having most of their replacement bushings & other smaller parts for the antique tractors built by outside small job shops so in a lot of cases has simplified the machining procedure to keep the cost down & make machining easier.. As long as that bushing fits both the pulley hub & crankshaft it will work good. Be real careful when driving [or pressing] that bushing in, if you crush it or distort it in any way you will then have to ream it to fit the crankshaft.. I usually make a driver on the lathe to fit the bushing inside diameter & hold the size while pressing in to prevent distortion.. Quote: �How far should the brass bushing be put in?� �.. Answ, same place as the old one was.. If you don�t know where it was just center it in the hub best as you can.. As long as it doesn�t stick out either end you won�t have a problem.. I usually try to keep them as close to the gear end as I can without sticking out as that increases the load center between the bushing & bearing & helps the pulley handle a tight belt load better. Quote: �Also which way does the concave washer go in next to the bearing? The parts book picture doesn�t seem to help� �.. Answ, that�s a good question.. All I can do is tell you how I do it & why.. That concave washer is concave so any oil that flows out between the bushing & crankshaft will be allowed to flow behind the concave washer & back through the oil return holes in the pulley hub.. SO, place that concave washer so it doesn�t block the oil return holes when partially compressed� The concave/convex portion of that washer must NOT touch the roller bearing roller ends either.... I haven�t ever seen any credible published data on that washer direction so use the above to make sure all the criteria is met & it will function fine.. I usually use a little sealer on the OD of the concave washer to seal it to the pulley hub to prevent oil from migrating past the OD of the washer.. [email protected]
