36 A Powerlift
Bruce
08-02-2004 19:02:15
The powerlift on my 36 A won't go down until I take the PTO out of gear. When lift tops out it seem to load the engine a little. My IT manual don't address this problem. Please help.
Bruce
Clooney
08-03-2004 04:34:24
 Re: 36 A Powerlift in reply to Bruce, 08-02-2004 19:02:15
Bruce, first make sure it CAN go all the way up.. If something is limiting up travel you will have problems..
If all ok with the travel then you probably have an internal problem [possibly with the cam lever].. It sounds like the regulator valve is functioning [engine loads but doesn�t stall] but the cam isn�t releasing for some reason..
You might want to pull the P/L box off for a look..
[email protected]
Bruce
08-03-2004 08:11:29
 Re: 36 A Powerlift in reply to Clooney, 08-03-2004 04:34:24
Thanks Clooney, I'll take the p/l off and look.
