FLOODED 4710 Tractor !!!
MLB
08-02-2004 18:40:12
Guys,
I have a MAJOR problem.
In the recent floods in Texas my almost new 4710 4wd hydro trans got FLOODED.
And I mean UNDER water.
Does anyone know if I need to get it Totaled or is it REALLY going to be ok after we change all the fluids and filters. (Like some are telling me?)
Thanks guys a ton for any help.
G-MAN - long post...
08-03-2004 10:35:22
 Re: FLOODED 4710 Tractor !!! in reply to MLB, 08-02-2004 18:40:12
Here are Mother Deere's recommendations for returning a flood-submerged tractor to service:
Problem:
Water damage causing rust and dirt or silt contamination.
Solution:
The procedures listed below should be considered where possible:
1. Do not attempt to start tractor as water in the cylinder(s) will cause hydraulic lock, which may result in major engine damage. Also, contaminated oil will be circulated throughout the hydraulic and transmission systems. If the tractor must be moved to perform a cleanup, place the transmission in tow and haul by truck.
2. The engine should be completely disassembled, inspected for damage and thoroughly cleaned. Tractor works service information bulletin r79-20-11 should be referenced for cleaning procedures. Oil coolers, intercoolers, rocker arms and shafts, turbo chargers and injection pumps are assemblies on which additional cleaning efforts need to be applied in order to assure future reliability. Any parts which exhibit rust must be replaced. All seals, gaskets, etc., must be replaced.
3. Drain the transmission case, clutch housing, final drives, and front axle compartments where applicable. Flush transmission with procedure outlined in the technical manual under hydraulic repair, using an oil transfer pump. Remove the transmission pump inlet screen to facilitate removal of debris. Do not reuse oil drained from compartments. When compartments are drained, flush as soon as possible and refill with clean oil. If compartments are drained and left empty, rust and corrosion will form. After flushing, circulate hot air throughout case if possible; try to dry any moisture remaining on components.
4. Remove any drain lines to the transmission sump to see if water is present (such as drain from main hydraulic pump, selective control valves, etc.). If water is present, the component should be disassembled and thoroughly cleaned.
5. Drain and flush the fuel tank. Dry completely before refilling.
6. Replace all hydraulic, fuel and air filters. Lube all grease zerks sufficiently to flush water and debris. Repack front wheel bearings on 2wd tractors. If applicable, install grease fittings and lube to flush water and debris from axle outer bearings.
7. Clean external debris from radiator, oil cooler, condenser, exhaust system, intake system and from all external control linkages, etc.
8. Flush the air conditioner compressor clutch with clean water.
9. On most models with sound gard body, the blower motor, right wiper motor and air conditioner temperature control will fill with water when submerged and will probably experience early failure. The left hand wiper motor is sealed and should be okay.
10. Clean and replace fresh air filter.
11. Dry the radio, speakers and switches/controls inside the cab with hot air.
12. Disconnect all sealed electrical connections and clean and dry if water is present.
13. Remove all electronic control units; ccu, hcu, etc.. Disassemble units and clean and dry if water is present. Dry the internal components with hot air.
14. Rinse the alternator with clean water. When tractor can be started, observe the voltmeter for charge. If charge low, remove slip rings and brushes and clean. If battery level is overfilled, drain to full level and charge at low rate. If specifics gravity is less than 1.25, dump the battery fluid and refill with dry charge fill.
15. When the tractor has been reassembled and can be started, finish the hydraulic cleanup procedure as outlined in the technical manual. Run tractor at operating temperature for extended period to evaporate any remaining moisture.
JDGnut
08-02-2004 20:27:01
The hydraulic system is not that big of a concern as long as it is taken care of right a way.. and nothing starts to rust... the electrical components are going to be anothet story... Usually with flooded vehicals.. (this is a little more automotive.) we could clean the switches and sensors and get everything working again... but they tended to fail over time... I would be more concerned with the alt, starter, gauges... if it was one that has the E-hydro.. then it has a computer on it too.. so lots of little stuff... Lots of rain in TX..... sorry to hear about your 4710..
JDGnut
leon
08-02-2004 19:41:43
I'd sugget that every major component of the tractor that was under water needs to be totally disassembled and cleaned. Don't turn a thing until this is done. Of everything, including the engine, I suspect the hydro-transmission is the most critical. It could well be that such total disassembly would cost more than the tractor is worth.
