420/430 differences
Brian
08-02-2004 11:23:10
Hey guys,
My father-in-law has a 430W with the 5sp and live PTO. I have used it quite a bit lately. Nice tractor to say the least. A friend down the street bought a 420 a few years ago (after borrowing my father-in-laws 430). The overall condition of the 420 was poor, but it did run ok. They used it some... but the poor condition of the tractor led to parking it in favor of a new Kabota. I am thinking about trying to aquire this old 420. It has a 5sp and live PTO I think. I know the HP is the same as my paw-in-law's 430. What other differences between the 420 and 430 are there? I really would like to find an old deere in the boneyard that had the factory reverser..... can I install it on the 420? What is involved? I would proabably completely disassemble tractor and fix what is broke and put a new coat of paint on it. It would primarily be used with a 60" or 72" finishing mower to cut my 2.8 acre yard. I think they (2 people went in together to buy it) want $1000 for it. My father-in-law says it isn't worth that. He said $500.
Any thoughts would be appreciated.
Mark57-420
08-03-2004 05:41:25
 Re: 420/430 differences in reply to Brian, 08-02-2004 11:23:10
It appears to me that the tractor does run (or at least did when parked) but just looks bad. That's kind of the condition that I inherited my 420 in. It looks bad, but runs great. Anyway, assuming that the tractor does run okay, I'd say $1000 is almost a steal. I've been seeing tractors in normal condition (for 45 years old) going for over $4000. I really appreciate the fact that Deere still stocks most of the parts for the tractor. It'll save the agrevation of hunting through junk for parts, assuming you want to pay for new. I also find a lot of NOS parts on e-bay for a decent price.
In my opinion, as long as it runs okay, $1000 is an absolute steal. However, as with any old tractor, be sure to look it over REAL GOOD first.
BTW - you may want to make sure you get the front weights. A 60" finisher on the 3-pt would probably make the front end a little light.
Good luck and enjoy!
Henry J
08-02-2004 18:56:19
Brian
In late 58 JD also put the 430 type power steering on the 420 (has a separate ps pump) that is nice stuff.
As far as buying one and going all through it, I assume you are in the mood for big bucks. If that 420 dont run good enough that you can try it out in all five gears, after what I went through, I would be spookey on the deal. Unless, that is, if you could get it for a parts tractor price. That way you could turn around and unload for a parts tractor if it turns out to be wormy.
Good Luck
merle
09-03-2004 12:52:09
 430 john deere 2001 model in reply to Henry J, 08-02-2004 18:56:19
hydrolic fluid leaking from under center of tractor square opening center area looks like it is coming from around drive shaft area bolt below area was loose tighten it. does not leak all the time but when it does it flows as a fast steam of fluid. any suggestion would be helpful thankyou [email protected]
buickanddeere
08-02-2004 14:55:35
No difference between a 1957 420 slant dash and a 430 except the sheet metal.
buickanddeere
08-03-2004 05:55:32
 Re: 420/430 differences in reply to buickanddeere, 08-02-2004 14:55:35
ZZZZZzzzz, it was 58 when the slant steer 420 came out. 57 for the yellow stripe staight steer and the 56 all green 420 with the 40 style starter and only the four speed trans.
Ray
08-02-2004 18:44:37
It has to be a 1958 to be a slant steer 420.There
are differences between the 420 and 430 engines.
The 420 has a dipstick on the left side of the block and the oil fill is on the vale cover.The
430 has the dipstick and oil fill hole (all in one)on the right side of the block.The late 420
tractors (1958) have the same block as a 430 but
the casting for the right side dip stick and oil
fill are not machined out.
Henry J
08-02-2004 18:51:25
 Ray on the Dipstick in reply to Ray, 08-02-2004 18:44:37
Ray
Don't be surprised if some day you may run into a 420 with the oil fill at the dipstick like the 430. I foggily reading something that JR Hobbs wrote about the 430 series motor/block coming out earlier on the 440 or something like that.
Anyway, I bet that in late 58 some or all of the 420 got the 430 type block that was dropped at the assembly line. I have a 420 in my barn with the oil fill at the dipstick and it also has the rock shaft housing that has the bushings in it.
Could be just an anomily though
Ray
08-03-2004 04:49:24
 Re: Ray on the Dipstick in reply to Henry J, 08-02-2004 18:51:25
I'll bet the engine was probably changed sometime
to a 430 block,the replacement block probably
was the 430 block.I've got a 1958 model 430S and
a 1958 model 420S side by side in the barn,the blocks look the same except the oil fill on the 420S block hasn't been machined out,the dip stick is still on the left.The 430 S has the dip
stick hole on the left cast into the block but it's not machined out either.I've seen several M tractors with 330 blocks that look original.
buickanddeere
08-03-2004 05:57:53
 Re: Ray on the Dipstick in reply to Ray, 08-03-2004 04:49:24
Didn't the M,40,320 & 330 use the same block casting/part number?
Ray
08-03-2004 14:48:29
 Re: Ray on the Dipstick in reply to buickanddeere, 08-03-2004 05:57:53
Don't know about the part number,but they all will interchange.I know of a guy in NC who junked
a 330 to fix up an M.
buickanddeere
08-04-2004 05:19:30
 Re: Ray on the Dipstick in reply to Ray, 08-03-2004 14:48:29
Does this guy in N.C. understand the extent of his mistake?
Ray
08-02-2004 18:47:41
 Re: 420/430 differences in reply to Ray, 08-02-2004 18:44:37
Also reverser tractors don't have live pto.
