Model G Large PTO Shaft
Ben.So.Tex
08-02-2004 08:56:29
I am trading one of my tractors for a G, this tractor has Power Block stamped on the block,and the pto shaft is about 1 3/4 round it is alot lager than the standard size, Is this shaft normal for the power block, and what was it propose? I looked at another G yesterday and it did not have power block stamped on the block, and the pto shaft was normal size. Give me some info on this thanks,Ben
JDGnut
08-02-2004 20:33:52
 Re: Model G Large PTO Shaft in reply to Ben.So.Tex, 08-02-2004 08:56:29
Ben.. I think they answer the PTO question for you... the PB is just an aftermarket block that was sold by TSC.. for the G's it was a 6.5 bore.. If you took the block out of the tractor... it could be sold for about the same as the rest of the tractor... they are big with the tractor pullers... JDGnut
Ben.So.Tex
08-02-2004 10:30:10
 Re: Model G Large PTO Shaft /Thanks Guys in reply to Ben.So.Tex, 08-02-2004 08:56:29
n.t.
John T
08-02-2004 09:40:53
Ben, I agree that some of those G's had that larger 1 3/4 Power Shaft REGARDLESS if any Power Blocks or not. Having or not havign it wasnt the determining factor as far as Ive ever known also. Ive used the reduccer on G's Ive owned and never had any problems either.
John T
Thane
08-02-2004 09:21:00
My dad has a 1946 G. It has a large PTO shaft too. I know he has a reducer on the shaft, so the 'normal' PTO equipment fits fine.
Bob
08-02-2004 08:59:13
While I can't quote specific serial numbers, offhand, the 1-3/4" PTO shaft is a change at a certain serial number, and has nothing to do with the presence or absense of a powerblock.
mike
08-02-2004 15:20:06
 Re: Model G Large PTO Shaft in reply to Bob, 08-02-2004 08:59:13
both my 44G and my 48G had the same big shaft
Will P
08-02-2004 20:44:10
 Re: Model G Large PTO Shaft in reply to mike, 08-02-2004 15:20:06
Deere never made a 44G, or really at that time the G was called the GM. The GM was killed mid 43 and never returned until mid 45.
Will P
Clooney
08-02-2004 09:23:15
Ben, just to add to Bob's response.. Before there was an industry standard to set specs on certain tractor equipment & functions there were a few different sizes of power shafts.. On the larger tractors the PTO shaft couldn�t even take full engine power without failing.. Deere went with the 1-3/4� on the G due to the higher engine & PTO torque available on that tractor.. Once there was an industry standard Deere dropped back to the standard.. Deere did offer a kit to downsize that shaft but I sure couldn�t tell you how many have been converted� There are adapters made but they lengthen the PTO shaft & place the front U joint awfully far rearward.. I have cut a few of those 1-3/4 shafts off & welded on the rear piece of a later shaft & had it function without problems..
[email protected]
