JD 420 Carb Problem
JD Earl
02-01-2004 12:26:01
OK Here is goes. I have a 56 420 that cannot idle. The govenor keeps pulling the carb open as soon as it starts to idle down. In other words it idles high then low, high then low about every 3-6 seconds.
Here are the 2 things I have noticed.
1.The main butterfly is a little stiff.
2. The choke has a loose metal piece on it that is suposed to have a spring across it. The spring is missing.
I have an old very used carb that I borrowed from my uncle and put it on and the tractor runs great! I need to get mine working so I can give it back.
Any help would be greatly appreciated.
JD Earl
Hayman
02-01-2004 19:13:23
 Re: JD 420 Carb Problem in reply to JD Earl, 02-01-2004 12:26:01
My 420 has been running that way for 20 years.I'm used to it now, kind of like it.
Wayne in Tn.
02-01-2004 13:57:17
JD Earl. I would say it's time for a carb. rebuild and cleaning. Most of the time people will diagnose the (high-low) thing as a govenor problem. But actually I have never seen one with a bad govenor, it's always a carb. problem. You will have to open all the idle passages with carb. cleaner and run a small wire through them. The main jet needs to be removed, it has a series of tiny holes running the length of it. This is the brass tube that sticks up in the throat of the carb. It is removed from the bottom, underneath the L shaped screw or 'power screw' Sometimes these are a PAIN to remove, you need a good flathead screwdriver and possibly some heat. If you need one, I can e-mail you an exploded diagram of the carb. My e-mail is: [email protected]
