How many turns of the flywheel should it take to s
old
02-01-2004 10:56:33
I know this might be a dumb question but any how, how many turns of the flywheel should it take to start a hand start B when its around 20 degrees out?? Is ay 6 or 7 turns good or should it start on 1 or 2? I started my B the other day it was around 20 out and it took 6 or 7 turns to start, just wanting to know it I still need to adjust some things or it that good???
Deereman
02-04-2004 14:14:15
 Re: How many turns of the flywheel should it take in reply to old, 02-01-2004 10:56:33
My 1944 A usually cranks in at least 5 turns, usually 1-2 in the summer. My tractor has .45 over high top pistons in it requiring a little bit more choke than most.
buckeye al
02-03-2004 14:43:05
Mine always seems to start on the last turn. Don't know why just seems to work out that way.
Dumb comments aside, you didn't say what year your's is & that makes a difference on how quickly the fuel gets into the chambers. Late styled B's didn't choke as hard as the earlier ones. It depends on how you count the turns too. Many times you'll have to turn the crank one and three fourths rotations before you have even the first opportunity for the engine to start! 6 or 7 @ 20* is not a problem as long as it goes on that last turn!
Keep smiling.
old
02-03-2004 16:29:06
 Re: Re: How many turns of the flywheel should it t in reply to buckeye al, 02-03-2004 14:43:05
Its a 1935 B, what always get me is on the first pull it pops and then it takes 5 or 6 more for it to fire up
Paul from MI
02-01-2004 13:28:11
Mine usually starts in about 4-6 turns in the winter, unless it's down around zero. It is very good condition, with around 400 hours on a major overhaul. The carburetor has recently been completely cleaned, new float, nozzle, etc. and the mag has one of Roberts hot coils in it. In other words it's about as good as it gets. In the summer it will start on one or two turns. I'd say it is OK.
Paul
