D JD on LP
Billy johnson
08-01-2004 05:06:54
I have wico mag #XH1042 on this D LP was wondering if it is the correct one for this tractor that is on LP. The problem is it backfires through the carb when you try to start up. I have good comp so I don't think it is the valves, have checked valve lash and increased it, checked timeing it seames ok,but what else?????
Earl S
08-01-2004 16:33:12
 Re: D JD on LP in reply to Billy johnson, 08-01-2004 05:06:54
Billy, Unburned fuel in the exhaust. A Wico XH series mag fires on comp and on exhaust stroke .I would go with a mag that only fires on comp.The numbered series tractors with factory equipped LP and Delco dist. only fired on comp.You will need a mag with a gear driven rotor. Email if you need help.Earl In Illinois
Billy Johnson
08-01-2004 18:28:05
 Re: D JD on LP in reply to Earl S, 08-01-2004 16:33:12
Earl I tryed the Email was not able to send it,got a wrong address or server. Would like to get the other #s of mags that mite work. Thanks for the help.
CLW
08-01-2004 11:05:09
There was a person that posted on here or the other board six months or so ago with a pyramid scheme. Folks got ticked off and someone was able to track them down. They found there address, how much they paid for there house, what the size of the house was, what it was made of, the three phone numbers in that house (and posted them) and where the home owners worked. One was a computer programmer. There was some other information that I don't recall but it sure put a stop to them. This sucker doing the imposter post on here will get cought and it is going to be funny. CLW
G-MAN
08-01-2004 10:07:00
 Re: D JD on LP in reply to C1ooney., 08-01-2004 09:57:28
no way clooney your full of it
buickanbdeere
08-01-2004 10:12:19
 Re: D JD on LP in reply to G-MAN, 08-01-2004 10:07:00
imposters!!!
