Vintage JD photo-820 playing in mud
Brandon
08-01-2004 02:00:13
I bought this photo recently off Ebay, I thought it was cool....
Looks like a green dash 820 pulling a modified R (which looks to be yellow!) in VERY sloppy mud!
Go here to get a bigger version! BIG Version
Note a few oddities....
"John Deere" text emblem on 820 grill, instead of round design.
The R is running, yet I see no throttle lever, or air and exhast stacks!
I've seen a VERY similar photo to this in Two Cylinder Mag, but it has an 830. The R looks exactly the same, but it has a throttle lever
Brandon
My Industrial John Deere website
John Deere Diesels
The LaGrange Engine Club
brian
08-01-2004 17:56:54
 Re: Vintage JD photo-830 playing in mud in reply to Brandon, 08-01-2004 02:00:13
the R tires are backwards also whats the cord that is hooked from the seat to the hood
CMB
08-01-2004 06:27:58
 Re: Vintage JD photo-820 playing in mud in reply to Brandon, 08-01-2004 02:00:13
Oops! On second glance It's clear that's an "820", not "830".
CMB
08-01-2004 06:25:37
This photo was, most likley taken at John Deere's testing facility at Waterloo. Notice that the rear tractor has it's drive tires reversed indicating it was being used as some sort of a "test mule" to put a load on the "830". The box where the generator would be, might be instruments to measure whatever they were trying to learn that day.
msb
08-01-2004 11:51:44
 Think you are right CMB in reply to CMB, 08-01-2004 06:25:37
The operator appears to be wearing an engineer's lab coat in the picture.
Brandon
08-01-2004 10:32:22
 830 in mud photo in reply to CMB, 08-01-2004 06:25:37
Here is the 830 photo (From an old Two Cylinder article) you were thinking of:
Now the R does have a throttle lever, but the pulley isn't moving!
Brandon
720Deere
08-01-2004 05:39:28
Doesn't it look like some kind of control rods at the front of the R hood? What's with the funny looking box where the generator would be on the R? Maybe this is some kind of tandem rig.
Plant Doctor
08-01-2004 06:14:14
 Re: Vintage JD photo-820 playing in mud in reply to 720Deere, 08-01-2004 05:39:28
720Deere: You have a very good eye, I looked at the pictures what I thought to be very carefully and I never noticed that box in the generator location. Take a look at the round emblem on the R and see if you do not think it looks like a tachometer with a gauge to the left of it. It looks like this R is set up to operate without a driver??
720Deere
08-01-2004 07:45:35
 Re: Vintage JD photo-820 playing in mud in reply to Plant Doctor, 08-01-2004 06:14:14
I believe somebody over on the Johnny Popper board nailed it on the head. The R has been converted into some sort of dyno or load creating device. Maybe that "box" creates and measures some sort of hydraulic load through the R cylinders. If only Nebraska had an old R like that for the Farmalls to "attempt" to drag around!
Gary U in NJ
08-01-2004 03:10:16
 Vintage photo in reply to Brandon, 08-01-2004 02:00:13
Brandon
Great shot! I'm a bit miffed also on the missing stacks and the emblem.
BTW, we are still enjoying your site, many thanks!
Gary
