FH Rear Wheel Weights?
dan_41jdh
02-01-2004 10:39:59
Could anyone shed a little light on some weights I have? They are cast iron with raised letters "F&H", and below that is "W.No 162". Diametrically across from those letters is "PATENT No 1.487.257". I assume the weights were made by French and Hecht, and the "162" means they weigh 162 LB each? (Sure feels like it!) What did they fit; when were they made; were they sold through Deere dealers, or were they strictly aftermarket items sold through third party retailers; etc. Thanks for any information.
Duane Larson
02-01-2004 16:02:15
 Re: FH Rear Wheel Weights? in reply to dan_41jdh, 02-01-2004 10:39:59
Dan,
Your weight was the standard weight sold by JD for tractors on rubber tires. Different sets of fasteners were sold for use on spoke, cast, and pressed steel wheels. They fit about everything except some of the non-styled AN, AW, BN, and BW tractors which had larger hubs. Depending on which reference I use, printed weights vary from 135 - 141 lbs each, without mounting hardware.
JC
02-01-2004 14:25:43
Dan,
I took weights off a "D" that I am restoring. They were F&H and I'm sure they were "162"s. The tractor is about 50 miles from here so I'd have to check next week. I don't know the history of this tractor so I don't know if these were factory installed or aftermarket. I posted a question about them last summer and I recall the opinion was that they were a factory option. They fit correctly on the factory installed round spoke rubber tire wheels that are on the tractor.
JC
JC
