4010 pto clutch noise
Derek Edwards
07-31-2004 19:37:59
I was cutting hay today and the pto of my JD4010 suddenly started making a loud clunking revolving noise when I engaged the clutch. The noise seemed to be coming from the clutch housing. What is the problem?
Thanks
Derek Edwards
ronb
08-04-2004 00:52:33
 Re: 4010 pto clutch noise in reply to Derek Edwards, 07-31-2004 19:37:59
a lot of folks dont know that there is a grease fitting on the throwout bearing. my dad has a 2750 that he bought new years ago and the other day i climbed on it to hook up to the baler and as i let the clutch out it made an awful grinding noise. after i questioned him about it he said it had been doing that for years. i told him my 4010 had this fitting and after we searched around a little, sure enough his had one too. it was in a different location but it was there. i was afraid that the damage was done but it has been quiet since.
Derek Edwards
08-05-2004 06:09:37
 Re: 4010 pto clutch noise in reply to ronb, 08-04-2004 00:52:33
Thanks everyone for your ideas. Much appreciated.
Fortunately on inspection the throwout bearing was in good condition and still had grease.
The noise problem turned out to be caused by the ajustable flat headed bolt behind one of the pto clutch fingers that is screwed in the end of the sliding pin. The head had sheared off and so the finger could flop forward.
It was easy to repair as it was the finger nearest to the inspection cover. The guy at the John Deere dealership said it was a fatigue problem that he had occassionally seen. Cost of parts $10. After my visions of having to split the tractor that was a great relief!
Back to baling. 100 acres done. 30 to go.
regards
Derek
twopop
07-31-2004 20:24:50
had the same thing today.the pin came out of the 540 shifter and caught in the 540 gear teeth.a piece of the pin stuck in the gear and would make a clunk,every turn of the gear.see if you can turn the pto output shaft and feel for a tight spot.
Bobx
07-31-2004 20:14:50
Remove the inspection cover under the flywheel (DON'T START THE ENGINE), and look up there with a light and see what's banging around. Do not start it until you find what's wrong, or find an expert to help you.
A neighbor had a similar problem, and when he re-started the tractor, the loose clutch parts "ventilated" both sides of the clutch housing, and he was due for a change of undies!
It could also be something in the PTO gear train, but, for the power involved, it's best not to run the tractor until the cause of the noise is found.
msb
07-31-2004 20:03:21
Take the inspection cover off (undreneath) and have a look.Just a guess but maybe you had a clutch operating finger come loose or wear through the bearing surface area of a finger.Could also be the bearing itself.Do you make a habit of greasing the bearing each season?
Derek Edwards
07-31-2004 20:16:03
 Re: 4010 pto clutch noise in reply to msb, 07-31-2004 20:03:21
Thanks I'll have a look. Unfortunately I have never greased the bearing as I did not realise that it needed doing.
regards
Derek
