Larry, you can check the coil to a certain extent by using an ohm meter. The coils primary resistance measured between its lil + and - terminals should be in the vicinity of 1.2 to 3 ohms or so depending on if its a 6 or 12 volt coil. If youre measuring 12 volts on its input when the points are closed and their circuit working, it should be a 12 volt coil as the 12 indicates theres no series ballast resistor which should drop that to 6 volts or so if all is working. The secondarys resistance to the center HV terminal would be several thousand ohms. When doing these tests, unhook all leads to avoid voltage and other interfering circuit paths. NOTE, Even if the coil had continuity using an ohmmeter, that shows its NOT a bad open coil, HOWEVER, it could still be bad breaking down under high voltage. TROUBLESHOOTING: Hook her all back up, with the switched voltage to its high input side and low side wired to the distributor. When the ign switch is turned on, battery voltage should appear on the coils high input side. Place your voltmeter or test lamp on the coils other low to distributoir terminal side, turn her on and crank the engine over. A test lamp there should flash ON (when points open) and OFF (when points are closed) If the lamp never comes on there, the coils primary is bad/open,,,,, ,,,,or the points are never opening,,,,, ,,,or theres a shorted/bad condensor (remove its lead to points and see if lamp comes on, if so, bad shorted condensor or its wiring),,,,, ,,or the points wire is shorted,,,,, ,,or the distributirs side pass thru sud is grounded (use ohm meter to test that),,,,, ,,,or the points may have a shorted spring. If the lamp never goes off as engines cranked, the points are not closing,,,,, ,,or the wire or circuit is missing from the distributor to the points,,,,,or the distributors not well grounded to the tractor. She cant fire the coil unless its low side is getting a conductive ground return path via closed points and then the circuit is open when the points open. Be sure the condensor or its wiring is NOT shorted out and see if the lite comes on (when points open) with the condensor disconnected. To check for possible cap or rotor problems (if all the tests above pass)..... ..... Remove the coil wire from the distributor leaving coil end inside coil and place the exposed end to within 1/8 inch away from tractor iron like block or head etc. Turn her on and crank her over and a spark should jump that gap nice n blue each time the points open. If so there but NOT out the plug wire terminals,,,,,the cap or rotor is bad. Check it for cracks or carbon traces etc. If the cap n rotor are good but the plugs dont fire, the wires or plugs could be bad. Try different plugs or wires and by swappign sides se if any plugs fire as she is cranked. If fire comes out the coil wire per the above but no plugs fire, its gotta be a cap or rotor or plug wire or plug problem. NOTE if its the right cap, when the points break open the rotor tip should be lined up next to one of the caps internal pickup points. Be sure the points open on high cam,,,,, ,theres voltage present on distributors high side at all times when ignitions on,,,,, ,voltage on coils low side flashes on and off as distributor is cranked,,,,, ,,,condensors not bad/shorted,,,,, ,,no shorts in wires to points and no shorts in pass thru side out distributor stud,,,,, ,,coil has continuituy. Sorry, late for church gotta run I will chaeck back with more later Good Luck n God Bless John T
