2355 transmission
chris
07-31-2004 13:28:11
I just bought a 1991 JD 2355 MFWD. I am seeing that these tractors were available with 2 different transmissions. A top-shaft syncronized(TSS), and a collar-shift (CS). Can anyone tell me how to tell which one I have? Thanks for your time
ktp
08-27-2004 00:56:15
 Re: 2355 transmission in reply to chris, 07-31-2004 13:28:11
david val is right. The collar shift is backwards on the 3-4 range. I have seen this on many "boat tractors" from overseas. they work ok but can cause some difficult shifting if your trying to shift on the go
david val
08-01-2004 00:02:45
the shift pattern of the right shift lever is different. in sinchro transmission it like a 4 speed car: 1st- left front, 2nd left rear, 3rd- right front, 4th- right rear. you can also shift on the go tike a car witout grinding gears. in collar shift transmission the 3rd and 4th change their places in the shift pattern and you need some expertese and double clutching to gange gears witout grinding them.
david
buickanddeere
07-31-2004 13:35:18
There were more transmission versions than that. What are the serial numbers on the transmission case? I have the 2355 parts CD and it explains some of the option codes etc.
