2440 Hydraulic Problem
FrankT
07-31-2004 07:28:12
I have an older JD 2440 that runs great. However, have two hydraulic problems. First, the power steering wangs when I turn in one direction. Doesn't do it in the other direction. Second, the three point hitch vibrates as it rises. Has the power to lift, but vibrates and jerks when it does rise. Now, sometimes after I run the tractor for a while, the power steering works perfect in both directions, but the three point won't rise unless I turn the wheels all the way to the left. Is there a valve sticking somewhere??
FrankT
08-01-2004 05:50:52
 Re: 2440 Hydraulic Problem in reply to FrankT, 07-31-2004 07:28:12
Thanks for the follow up. I appreciate the response. I'll look at both of those items and let you know the results.
david val
08-01-2004 00:12:38
you certainly have a problem with the steering unit. in some cases internal leak in the steering affects the rest of the hydraulic system (rockshaft and scvs), have the steering unit repaired and the lift problem may be gone too.
david
R. John Johnson
07-31-2004 20:43:01
Don't know if it's helps, but we had a similar problem with the 3 point on our 2755. If you pulled up the lever too quickly it would raise, but shudder and rob hydraulic power to the remotes. If you pulled it up slowly it was fine.
I had the tractor apart and sent the 3 point cylinder to a good local hydraulic shop. All that was wrong was an broken O-ring in one of the valves.
Good Luck
John
