JD 50 Ignition
Don
07-30-2004 20:03:16
I have a rear exhaust 50 that looses power after working hard in warm conditions. Apparently the heat from the exhaust passing close to the coil and distributor causes those components to overheat as after cool down it's back to normal operation. I converted it to electronic ignition with little improvement. I have another 50 with the same ignition system and upright exhaust that runs fine under all conditions. Is there a coil available that can withstand the extra heat? Thank you very much in advance for any direction you can provide me!
Clooney
08-01-2004 08:26:19
 Re: JD 50 Ignition in reply to Don, 07-30-2004 20:03:16
Don, I don't recall the factory down swept exhaust passing that close to the ign coil on a 50..
Are you running a custom made exhaust? If so just move the coil to a cooler location [you can use a longer coil wire if needed] .. If you are running a stock 50 down swept exhaust maybe your coil is mounted in the wrong location..
I would suggest you first move the coil away from the exhaust.. Then if it still quits [my guess is it will] you might have a coil on that tractor that needs an external ballast resistor..
After moving the coil away from the exhaust run the tractor for a while & if the coil still becomes too hot to touch you probably need an external ballast resistor between the coil & ignition switch..
It�s not unusual to find the later 520 type external ballast coils installed on those earlier 50 tractors & those will overheat & shut down if operated at low RPM�s without a resistor..
If you can give me the coil number I might be able to tell you if it needs that resistor.. Some coils will also have �use external resistor� written right on them..
Any questions on the above just post back..
[email protected]
buickanddeere
07-31-2004 08:41:23
How many ohms is the coil and what voltage is across it?
John T
07-31-2004 07:49:14
Don, when you converted to that electronic ignition, did you retain the old original coil or go to a new one????? I ask cuz less spark energy after warm up can be a sign of a defective coil, regardless if any exhaust warms it up or not, so the elec ignition with the old coil wouldnt cure that problem. I recommend you couple an elec ignition with a high voltage high energy performance coil and run a wider plug gap to get the most bang for the buck from the capability of the elec switch. You would need to check with the elec switch vendor for coil and plug wire recommendations also.
Bad points or condensors can be less efficient after warm up, but the elec switch eliminated those components.
You could have other causes also, but if its a weaker spark at warm up causign your problems, you may well have a coil problem.
Good Luck n God Bless
John T
Mark
07-31-2004 05:23:42
As I remember the exhaust trails down below the axle and not that close to the coil. I would suspect a ignition coil going bad after it runs for awhile.
