Aluminum vs cast iron pistons
Mattg
07-30-2004 19:54:25
Hello All,
I have an 60 with a cracked block. I have a lead on a couple of blocks. One person has an block that has been bored out with new aluminum pistons in it. This 60 is an working tractor. I have done searches on this site, and the major complaints on aluminum pistons is they seem to cause vibrations in the tractor. I rebuilt an 41 B and had to put aluminum pistons in it, and have noticed this vibration. Now for the questions.
1. Would I be better off trying to find a block that is not worn to bad an use my orginal cast pistons?
2. Do aluminum pistons hold up?
3. Can the engine be rebalanced so that vibration goes away?
Thanks.
Matt
g pop
08-01-2004 20:46:52
 Re: Aluminum vs cast iron pistons in reply to Mattg, 07-30-2004 19:54:25
in the late 50's and 60's it was a common practice to "update" the horse power of the older two cylinder tractors , with aluminum pistons here in the midwest,this vibration is pretty much ,pardon the expression, "in your head" ,or the thousands of tractors that used them,and some still going strong ,would have self destructed a long time ago.
Bob-Wyo
08-01-2004 19:17:31
Mattg, the ones that I got from Hendricks were exactly the same weight as the cast ones I removed. about 20#, now I have seen other aluminum pistons that had a weight of 1/2 that, I would bet they would vibrate.
Give Jerry a call, @ 815-778-1900 he sill set your mind at ease on aluminum pistons use.
Sure like mine now, just wish they were 8 to 1's.
Bob
Toot
07-31-2004 21:19:05
Every JD I currently own has aluminum M&W or clevite pistons. I don't really understand what all this vibration youre talking about is. I went out and started all 5, revved up, idled down, did everything, did not notice anything out of the ordinary. The aluminum will add power and If price wasn't an issue, every tractor that would be in my stable would have them. I am the kind of person that wants every horse that can gallop aside from stroking, modifying the engine big time. They have a smoother sound with aluminum than the crack crack sound cast iron makes. My opinion.
720Deere
07-31-2004 19:26:54
John Deere balanced the entire assembly including pistons. By all rights, if you are going to change one of the previously balanced components, you will have to balance the assembly again. You wouldn't change tires on your car and leave the old balance weights on the rim would you? The cluch driver is even part of the balance on the larger Deeres.
You either re-balance or live with the vibration. Then again, they shake so much already what's a little more.
Mike M
07-31-2004 16:34:56
I have been around a few A's and B's with aluminum pistons they were the older M & W ones which may be of better quality and I have not noticed any unusual vibrations. I did notice that the aluminum pistons reved up faster and didn't lug as good,can't prove it but it did seem so. Most were add power pistons which did make more HP.
Bus Driver
07-31-2004 14:38:38
Matt, would sleeving salvage your cracked block? The aluminum pistons most likely are lighter than the original cast iron and thus the vibration.
jc
07-31-2004 05:20:12
Mattg
I was faced with the same decision. I heard about the vibration problem with aluminium pistons and also that some aftermarket aluminium pistons are not of good quality. Also, since aluminium expands more with temperature than cast iron, more cold clearance is required.
My original pistons were in great shape so I ended up sleeving the block back to standard bore and using these pistons. For pulling and show, I'd be more adventuresome, but if this is a working tractor that you are going to be relying on, personally I'd go with standard or oversized cast pistons in a good block.
Others on this forum with more experience can give more definative advice.
JC
jc
07-31-2004 05:18:51
Mattg
My original pistons were in great shape so I ended up sleeving the block back to standard bore and using these pistons. For pulling and show, I'd be more adventuresome, but if this is a working tractor that you are going to relying on, personally I'd go with standard or oversized cast pistons in a good block.
Others on this forum with more experience can give more difinative advice.
JC
