567 jd baler
david
07-30-2004 18:38:01
I lost a 567 baler to fire. Only 2300 rolls, ejected last bale and shutdown for the day, fire started up about 20 minutes later. Anyone else with problems on 567.
R.J.
07-30-2004 20:00:59
 Re: 567 jd baler in reply to david, 07-30-2004 18:38:01
On my 530 J.D. baler I always check all bearing points and clear away all loose hay and debre at end of day when I shut down, and also check bearing points several times during the day.
I finally got the point off doing this after loosing 1 baler and two fires in which I lost several bales of hay and in one case about 20 acres of unbaled hay.
R.J.
david
07-30-2004 20:18:13
 Re: 567 jd baler in reply to R.J., 07-30-2004 20:00:59
I did such checks the night before, but was running late the day of the fire and didn't check. Never again...
