Steve, first guess would be the manifold heat control isn't set correctly.. It needs to be set at EXACTLY hot or cold. If in between it plugs off part of the exhaust flow.. Next would be a carb problem.. The carb on that 60 has a separate idle system for both sides & one side can function perfectly while the other side can starve for fuel.. See if pulling the choke partially to mostly back on helps,, if so suspect a carb internal passage blockage or you have a cracked or leaking intake manifold on the low performing side.. You could also have the spark not sparking at the correct time or a spark plug that won�t fire under a compression load [try either swapping plugs from side to side or a new plug in the offending side].. Next, you could have a valve that�s not opening far enough due to a bent push rod or worn cam [it doesn�t take much valve lift to give cranking compression but takes more for it to run on that cylinder].. You might want to pull the valve cover & check the valve action.. If nothing obvious in the above you could have a severely coked up exhaust valve [on the back of the valve head].. While I haven�t seen one do that in quite a few years now I have seen some do that in the past & if that valve head is coked up enough it can severely limit the amount of exhaust that flows past the valve seat while running [usually when the exhaust valve cokes up it will pop back through the intake when under a load or when the throttle is advanced quickly]� It shouldn�t take long to check out all the above & if you still can�t get it to run on the errant side post back & we�ll give you more & some real unusual things to look at.. [email protected]
