1st Reduction Bearing Bushing kit ????
GeorgeK
07-30-2004 14:48:16
Any one know where I can get a bushing kit for the 1st Reduction gear cover (outer) bearing? This cover has had the bearing spun out in the past, and is egg-shaped. I need to either replace the cover (last resort) or ream out the cover and put either a bushing in, or an over size bearing.
Ralph mentioned that there was a reamer/bushing kit made by a company in Iowa(?). Does anyone know this company?
Thanks, George
ray
07-30-2004 20:25:35
 Re: 1st Reduction Bearing Bushing kit ???? in reply to GeorgeK, 07-30-2004 14:48:16
I REPLACE THE SINGLE ROLLER BEARING WITH A DOUBBLE ROLLER AND INSTALL A THINNER SPACER BEARING STORE WOULD KNOW # 35.00 BUCKS
GeorgeK
07-31-2004 13:16:19
 Re: 1st Reduction Bearing Bushing kit ???? in reply to ray, 07-30-2004 20:25:35
Thanks for the Info, Ray. That's good creative thinking! I would have not thought of a double bearing.
Still, I think I will go with the bushing by Paul. If you put too small of a spacer between the gear and the bearing, you could end up with a lubrication issue, and that bearing does not get good lube now.
Thanks again, GeorgeK
Paul
07-30-2004 16:49:20
I can bore the cover out and make the bushing for the new bearing if you send me the cover and bearing. I have done several ot them. I live in NW Iowa. Paul
GeorgeK
07-31-2004 13:02:25
 Re: 1st Reduction Bearing Bushing kit ???? in reply to Paul, 07-30-2004 16:49:20
Paul, altho Ray has a good idea (double bearings) I would rather have the bushing.
Send me e-mail with your phone and address, etc.
I did not hide it in this response. UPS OK for you? Let me know cost, etc.
Thanks, GeorgeK
DOUG
07-30-2004 15:58:25
HI I have the deere tool to cut the case for a sleeve. But your best bet is to take the new bearing to a machine shop and have them do it. I have done 2 of them but still had to have machine shop cut a sleeve. Hope that helps DOUG
GeorgeK
07-31-2004 13:19:20
 Re: 1st Reduction Bearing Bushing kit ???? in reply to DOUG, 07-30-2004 15:58:25
Thanks for the Info, Doug. Paul offered to rework it for me.
Ray had a good idea, double bearing. Creative thinking!.
