A JD frame change???
Jack
07-30-2004 13:22:12
My 48 A has the pressed steel frame with the flywheel completly covered with one gas cap.I have seen other 48 A's with open flywheels and channel frames.What my question was,were the 48 A's the only year for both kinds of frames and which kind were there more of that year the channel or stamped steel?Thanks
Mark
07-30-2004 16:46:23
 Re: A JD frame change??? in reply to Jack, 07-30-2004 13:22:12
The press frame started at 584000. The '48 A's started at 587349. So another words the '47 A's were angle frame until the last 3000 or so.
Loren-MN
07-30-2004 15:29:28
I saw that ad as well, and thought, that's not a 48, but earlier. There is also an ad for a 52 60, that doesn't look like a 52. No window rear wheels, square front?
Loren
Stan - Florida
07-30-2004 13:52:14
What serial number do you have? To my knowledge, the change was made at 584000, which was in the middle of the 1947 model year. Same thing for the B, which changed at 201000, also in the middle of the 1947 model year.
There has been a lot of discussion on here about open flywheels and the old-style frame, especially when someone has a '47 that is the old-style frame. For years, I thought that all '47 and newer A and B models had the pressed steel frame, square seat, etc.
Stan
Jack
07-30-2004 14:45:03
 Re: A JD frame change??? in reply to Stan - Florida, 07-30-2004 13:52:14
I am not to where I can see it but I do know it was between 587439 and 611921 which on my card shows it to be a 48.The reason I asked was there was a 48 A on the photo ads that had the channel frame and open flywheel which looked very different than mine.Jack
Leroy
07-30-2004 16:32:01
 Re: A JD frame change??? in reply to Jack, 07-30-2004 14:45:03
Sounds like he doesent know what he has or thinks by misrepresenting it he will get more for it, that open flywheel would also only be an all fuel tractor
