4020 Sterring
Jack
07-30-2004 05:59:11
Ok guys....I bought a manual.....Bleed the steering like it said 3 times.Got a small amount of air out the first time.It seemed to work ok till I took it for a ride.It still turn to the right slowly.It work great sitting still.Do you think I got air in it still or do I have other problems.The tractor sit for 7 years and I had to pull it 4 miles to get it home.I pull it slow and let wonder around on the road ...But it followed me home.Look pretty stupid with no driver.But wife was sitting on it for a while trying to steer it but got into truck with me and let it do its thing.Went around 3 corners by itself.Could I still have air in it,My brakes work good and 3 pt seems to turn ok but haven't put it to use since rebuilding the motor.Help....I need it for baling in a few days...
DON
07-30-2004 08:00:09
 Re: 4020 Sterring in reply to Jack, 07-30-2004 05:59:11
OVER HAUL THE STEERING MOTOR THE SEALS ARE WORN OUT. DON
thurlow
07-30-2004 06:44:19
Sounds like you've got problems with either the steering valve box or the steering motor; not at all unusual on these old tractors. If it's not dangerous to drive it down the road (sudden darting to one side), I would just use it.....
idontno
07-31-2004 06:09:13
 Re: 4020 Sterring in reply to thurlow, 07-30-2004 06:44:19
OK..I bleed it again and it works ok sitting still or at low RPM but to speed it up and drive it down the road it still has it's problem. Sometime when I first start it up it will be fine for a few turns then back to not wanting to steer,back to the right.It has no visible leaks.Nor does it act up and want to steer itself into the ditch.When sitting , idling it will turn itself to the left lock.Do you think it will come out of it?
