JD 520..left brake drum won't come off...!!
Ron
07-29-2004 19:31:45
I have a seal I need to change, and I CAN get the drum loose...it just WON'T come off...not enough room for it to clear the axle housing..yes I have the stud out..!!
Was there a broblem with clearance on these, and will I have to take the whole unit out of the tractor..to get it off..??
Thanks for any help..!! Ron..
Clooney
07-30-2004 04:27:47
 Re: JD 520..left brake drum won't come off...!! in reply to Ron, 07-29-2004 19:31:45
Ron, some of those 520 drums will just clear the axle housing & others will not.. The easiest way is to just remove the brake assembly to case bolts then pull the entire brake assembly off the tractor.. You could also just loosen the brake assembly attaching bolts & that will allow the assembly to move far enough to get the drum off..
If the interference isn�t too extreme sometimes backing the brake adjuster all the way off will allow the shoes to retract enough to get the drum off..
My personal feeling is you should pull the entire assembly if you are going to paint the tractor.. Then re-install the brake assemblies after painting as that allows a MUCH better paint job under the brake area & allows a more complete cleaning of the area behind the brake assemblies.. The other added benefit is installing new brake assembly to main case gaskets as the original gaskets will probably seep some oil after the painting & the tractor is used a while..
I have been removing the brake assemblies on all the 2-cylinder tractors I paint for years & years now..
[email protected]
Mike M
07-29-2004 19:37:56
I also have encountered that same problem.I think one time I was able to move the drum enough to pop off the brake shoes,once the shoes were out it came off. I also think it was very hard to get it back together that way a helper to hold the shoes on the pins may help. I also may have ground some off the boss on the axle housing on some tractors too.
Ron
07-29-2004 19:48:20
 Re: JD 520..left brake drum won't come off...!! in reply to Mike M, 07-29-2004 19:37:56
Thanks...!! I hesitate to grind anything off...you know how some "purists" ore about that....!! 20 or even 10 years ago I'd have ground it off in a minute..!! I could get the drum off ( I think) if I forced it, but I would damage the inner steel "Hood" over the splines...as it slid past the end of the shaft.. Thanks for the help..!! NOW...how about that Hub with the stripped Jack Bolts..????...!!!!
Mike M
07-30-2004 03:52:45
 Re: JD 520..left brake drum won't come off...!! in reply to Ron, 07-29-2004 19:48:20
Some of those same purists just spray paint on and have never torn one down.I like to get my mechanical things working first and worry about paint later. Try getting the shoes popped off first and work them out as this gains some room.
