JKC, Its probaly just semantics, but if it starts easily despite long periods of inactivity, Id say it has "decent" compression at least if an electric start. If the rings are badly worn, once the oil seal around them has drained off after long periods of setting, she may not start cuz the compressions too low. If thats the case and squiritgn some oil in the cylinders helps, Id call that low or poor compression, certainly not good or even decent. On a hand start where cranking is very slooooo wwwww ww, if they start easily after long setting, I tend to agree with you in general it has "good" compression. Low compression from leaky rings or valves doesnt create as much vacuum or compression and they can be indeed, harder to start. That can be compensated for to some degree by cranking them faster (less time for compression bleed off) or having better rings n vales in the first place, or squiritgn oil in the cylinders to seal the rings better. I guess if they start easy after setting without adding any oil to the rings, I would say thay have decent compression if an electric start and good if a hand start. Good Question, Good luck n God Bless John T
