630..Jack Bolts stripped..now what..??
Ron
07-29-2004 19:27:35
The jack bolts have good threads, so I guess the threads in the Hub is shot.... What is your best guess..?? Should I Heat the hub and with the big bolts loose, try to drive the wedge out..??
I have a real good "Bull Pin" and a sledge...
Thanks.... Ron.
msb
07-30-2004 07:59:22
 Re: 630..Jack Bolts stripped..now what..?? in reply to Ron, 07-29-2004 19:27:35
You might try using a 10-20 ton hydraulic jack on the end of the axle and hook a chain through the wheel(a sort of hydraulic puller).Position the jack pump at the bottom first so you won't pump the jack full of air.But before you do anything remove all 6 bolts including the 3 on the inside.Tighten the chain up real good with the jack and then wallop the end of the opposite axle with a sledge hammer a few times.I have never had a any luck using a notched pipe myself.
Mike M
07-29-2004 19:45:48
I do not recommend heating those castings as I think it weakens them. I heated a set once to free the adjuster wheels and they cracked very easy when reinstalled. I seem to recall someone made a tool out of a large pipe notched on the end so it only touched that wedge when slipped over the axle used to beat on the edge of the wedge.You may be able to beat on the bolts that hold it tight maybe put in longer ones so they have good threads when loosened.
Ron
07-29-2004 19:50:42
 Re: 630..Jack Bolts stripped..now what..?? in reply to Mike M, 07-29-2004 19:45:48
Good idea...I will look and see if I have a good heavy pipe to use...maybe even make it into a kind of Slide Hammer...!!
d cotton
07-29-2004 20:58:28
 Re: 630..Jack Bolts stripped..now what..?? in reply to Ron, 07-29-2004 19:50:42
I made one of those. cut part of the end to clear the non wedge part of the wheel. Then welded a crosstie plate on the end to beat with the hammer.. It took several nice blows. and it just moved pretty as you please.
Ron
07-30-2004 11:11:38
 Re: 630..Jack Bolts stripped..now what..?? in reply to d cotton, 07-29-2004 20:58:28
Thanks for the help...!!
Ron...
