2010RU cylinder plate bore limits
Britt Misker
02-01-2004 08:38:00
I am in the middle of overhauling a 2010RU gasoline engine. My question is what is the maximum size that the cylinder plate can be bored to. The JD parts catalogue lists .020 pistons & rings availible. I understand that there are .045 aftermarket pistons & rings avalible. Is there enough wall thickness avalible to safely bore to .045?
Any help will be appreciated.
Thanks
Britt
Mark
02-01-2004 10:03:33
 Re: 2010RU cylinder plate bore limits in reply to Britt Misker, 02-01-2004 08:38:00
The plate can go to .045 if it is in good shape,no pitting on the outside. The only problem is the 1010&2010's tend to get hot when bored out that far if they are used hard. Not enough metal to dissipate the heat and the pistons start to scuff.
