720 D Head Gasket Problem ?
Mike M
07-29-2004 15:40:33
720 D just started blowing coolant out of the overflow. My first thought is a head gasket.Any thing else to check for ? Maybe thermostat stuck ?
This tractor had a head gasket replaced about 7 years ago,injectors rebuilt,valves done,resurfaced,new gasket put in right direction and coated with copper coat,retorqued after it ran awhile then again 1 or 2 years later when the injector lines were replaced cause one cracked not ran many hours. What else can be done to seal up these things ?
I was thinking new studs and nuts is all thats left not done.Anyone ever use a gasket from Luback Gaskets on one of these ? All help is welcome,can these be sealed up for a longer time ?
