6310 stuck in 4wd
Mike M
07-29-2004 15:24:44
A fellow that I have done some work for from time to time called me about his JD 6310 the 4 wd is engaged but the switch doesn't light up and when switched off it is still in engaged. My first thought is a fuse to control this blowed,but I know nothing about this model tractor at all.
Does it have a fuse for this switch and if so where is it ? What else should I look for ?
Any help welcome.
david val
07-30-2004 00:58:27
 Re: 6310 stuck in 4wd in reply to Mike M, 07-29-2004 15:24:44
the 4wd is engaged when there is no voltage to the solenoid and/or no hydraulic pressure to deactivate the spring loaded clutch.
first thing to do is to check solenoid activation: with key switch on and fwd off, check for magnetism in the fwd solenoid with a small screwdriver or other piece of iron. the solenoid is at the bottom of the transmission behind the fwd clutch bulge.
if it's not magnetized, look for electrical problem,(fuse switch wiring etc.).
if it is magnetized, there is either lack of hydraulic pressure or a problem within the clutc.
david
jeremy roberts
07-29-2004 15:39:21
There is no fuse, but there is a circuit breaker. Good luck finding it. Those tractors are known for that problem. Just tell him to use it like it is and not worry about it.
jeremy roberts
G-MAN
07-29-2004 15:42:25
 Re: 6310 stuck in 4wd in reply to jeremy roberts, 07-29-2004 15:39:21
That response is not from the real jeremy roberts. That is not his typical style of response. It's from the imposter. He really needs to get a life. Sorry I can't help with your problem, I just wanted to set the record straight.
G-MAN
The REAL G-MAN
07-30-2004 07:47:19
 Re: 6310 stuck in 4wd in reply to G-MAN, 07-29-2004 15:42:25
I see the little imposter twit has got around to using my screen name now. Get a life moron.
Kind of thought so.
07-30-2004 08:16:21
 Re: 6310 stuck in 4wd in reply to The REAL G-MAN, 07-30-2004 07:47:19
