Warren, that sounds kind of like you might have a cylinder mis-firing or not firing at all & that black oily substance is from the oil entering that cylinder past the piston rings then mixing with the unburnt fuel in there, then leaking out the exhaust pipe to pony manifold seam [I have seen that happen before].. Try running the pony for about 1 minute then reaching in [carefully] & feeling all 4 spark plug bases where they enter the cylinder head.. If you find a cold one [or at least colder than the others] you have found a low or non performing cylinder� If you have a mis or non firing cylinder try a new spark plug first & if still no fire look for a valve or compression problem.. If you have 2 cylinders on the same bank out look for a spark plug wire pulled loose from the back of the coil or a failed coil, or a malfunctioning set of points on the side.. If all 4 cylinders seem to be running hot & normal look for an over filled pony crankcase or a failed diaphragm in the pony�s automatic fuel shut-off allowing gasoline to flow back through the oil pressure line & into the pony crankcase [sniff the pony crankcase oil for signs of gasoline].. If this problem just started since the oil change make sure the pony crankcase isn�t overfull [an overfilled pony crankcase will allow the oil to foam & get sucked into the combustion process].. Any questions on the above just post back.. [email protected]
