6030 jumps sometimes out of gear
Markie
07-28-2004 22:14:02
Hi, my 6030 jumps sometimes out of gear, mostly 3rd gear forward and the low gear reverse. A friend of mine told me this is because the shifter lever and the quadrants are worn out. They look bad. So I've tried to order it at our local deere dealer But the parts AR44264 (quadrant) and AR59445 (lever) are not know in his system. So can anyone tell me if these parts are still in stock or not.
Thanks
Greetings Mark
thurlow
07-29-2004 06:14:11
 Re: 6030 jumps sometimes out of gear in reply to Markie, 07-28-2004 22:14:02
Hey Mark..... I have rebuilt these things (on 20 series); just take 'em apart; weld 'em up with a wire or acetylene welder and grind 'em down with whatever you've go to work with. Dremel tool would work; I use an air die grinder.
Bob
07-29-2004 00:19:34
JDPARTS shows both still good numbers, $US150.00 for the first number, and $US 125.00 for the second number.
If you shift carefully, you should be able to feel the detents (in the the transmission) drop into place. If this is happening, and it still jumps out of gear, there may be a problem in the transmission with worn shift forks or shift collars.
Markie
07-29-2004 03:32:23
 Re: Re: 6030 jumps sometimes out of gear in reply to Bob, 07-29-2004 00:19:34
Thanks Bob,
I'll tell my dealer that he has to order them. Thanks for the info on the shifter collars and forks. But I checked them with a friend and it looked good. But we aren't any experts. The only damage we can find is that both the quadrants are bad and the shifter lever and the shaft are both worn out.
Thanks again.
Greetings Mark
