3020 rockshaft leaking
glenn
02-01-2004 06:31:58
what is the most common place a rockshaft leak could come from ?
thurlow
02-02-2004 18:40:59
 Re: 3020 rockshaft leaking in reply to glenn, 02-01-2004 06:31:58
Assume you're not talking about the load control shaft; found it to be most commom place to leak; lowest point at rear of tractor (except drawbar/liftarms)?????
david val
02-01-2004 23:56:11
if you mean arms dropping, can be a leaking piston seal/scored cylinder, leaking lowering valve/seat, leaking thermal relief valve or leking flow control valve/seat.
david
G-MAN
02-01-2004 08:21:53
Can you be more specific about where the leak is? It could be nearly anything, from a blown o-ring to a loose fitting to a bad rockshaft seal. Where is the oil accumulating? You'll probably have to pull the toolbox/seat sheet metal off around the base of the seat to find it, if its coming from that area.
glenn
02-03-2004 06:43:13
 Re: Re: 3020 rockshaft leaking in reply to G-MAN, 02-01-2004 08:21:53
i fill the res up and over a period of time it will leak onto the ground . doesn't appear to be leaking under pressure .
