8520 air filter
Hey G-MAN
07-28-2004 11:26:53
our 8520 filter really fills up fast, local dealer put that update kit in the precleaner, it helped some but still fills up fast, you know any tricks, do you think they will change on next series ;;;; thanks billy
G-MAN
07-28-2004 13:45:04
 Re: 8520 air filter in reply to Hey G-MAN , 07-28-2004 11:26:53
By kit do you mean replacing the foam seal in the ejector fan housing? Most of the seals I've seen were squished out and leaking. That cures a lot of the issues, along with making sure the impeller runs close enough to the seal to create a good suction - I spaced several out with a washer behind the impeller. Also check the fit of the grille screen to the light bezel out front. There are springs that are now on all tractors that can be retrofitted to the earlier ones, and the springs keep the grille tight against the bezel. Also look for potential gaps between the bezel and hood molding. And if you've washed it much, make sure you don't have mud/dirt caked in the precleaner aspirator tubes. This has kind of been an ongoing issue, but the early ones that we got sealed up have been much better about keeping the filters cleaner. That whole new hood/intake design has kind of been a can of worms, so hopefully they'll get it squared away when the new ones (8030?) come out.
JDGnut
07-28-2004 22:50:21
 Re: Re: 8520 air filter in reply to G-MAN, 07-28-2004 13:45:04
Sounds like west TX... The update on the aspirator was little.. but replaced a lot... it sped up the speed and changed the housing.. I can't remember if it changed the impeller.. I was thinking it was a bigger impeller and new housing... Check the blades on the impeller..
I'll look to see what else is out there.. I know they have had a few problems in very dusty conditions... JDGNut
billy
07-29-2004 07:05:13
 Re: Re: Re: 8520 air filter in reply to JDGnut, 07-28-2004 22:50:21
thanks for replys, when they did the update they sped up the aspirator , and put new seal on it and did some work to the nose, smaller grill holes,and some air deflector;when I still griped about it they put a stronger sensor on air filter so it wouldnt tell you it was dirty, I think mother deere shot themselves in the foot on this one----- ----- ---billy
Mike M
07-28-2004 12:20:33
Come bring it to north central ohio this year it seems to rain all the time. Not much dust. How does it go in the mud ??
