 So, I put oil in both rear housings on my '47 B (the housing around the rock shafts and the housing around the pto). Both were essentially empty! Once there was some oil in there, the rockshaft worked like a champ! The only problem is the seal around the pto shaft is shot- oil just pours out of it. Can I replace this seal without a major teardown? Maybe it won't be too bad- just remove the housing cover, put in new seal and cover gasket and reassemble. Advice? Another question is this. The lift worked better than I thought in the following way. Mine has a lever to the left of the seat which activates a control on the lift housing. I've been advised that this lever simply replaces the foot pedals and it is still a powr-lift, not trol. There are 3 positions. Moving it to the raise position caused the rockshaft to rotate "up" until you return the lever to the middle. Same with down. The important point here is this- even tho this is apparently NOT a powr-trol, I can indeed stop the lift at any point in its range and it will hold there. So, I'm confused. I need to play with some of my neighbor's JDs to see how powr-lift and powr-trol differ in operation. This differs from the operation of the 3 point on my ford 650, which has an absolute position control rather than an incremental control like the JD.
