G-MAN, you say,, Quote: "That's all well and good, but that would be of little to no value in this case"..... Answ, I disagree with that statement as it would be a very good way to measure the torque [converted to horsepower if you like] required to turn both fluid filled & cast weight equipped wheels. That statement was in response to your original statements of: " but will it be measurable?� & �And if you were able to measure the loss, how would you determine if it were due to the actual fluid in the tires, or perhaps due to the weight of the fluid lowering slippage too much?� Quote: �Most tractor power train components, particularly final drives and axles, are so extremely overbuilt that they are fully expected to survive in even the most adverse conditions��. Answ, that is a true statement but has nothing to do with measuring the torque to turn the different weight set-ups.. In the testing mentioned above the axles were strain gauged to use as calibrated torque measuring devices not to measure destructive loads or abusive loads [that�s another type of test].. Take the axles out of the testing & use wheel torque measuring adapters if you like.. Quote: �Different soil types take different amounts of horsepower to move across� �.. Answ, again true but the tests to compare the torque to turn should really be measured under those different types of soil conditions to see if the difference in torque to turn varies by soil conditions or work loads.. That was mentioned in the first test set-up post. Quote: �The operator in the cab isn't going to notice even a 1% difference in horsepower requirements between types of ballast� �. Answ, probably not but the fuel usage over the life of the tractor, drive train wear, engine durability might [not will but �might�].. We won�t know if the horsepower difference is 1% or maybe more or even maybe less until the tests are run. Quote: �If it was of any consequence, you can be sure one of the tractor or tire manufacturers would have done the testing and published the results� �.. Answ, how do we know they haven�t.. Obviously the power loss isn�t great or there would be all kinds of published data.. The originating post of the thread wasn�t how much power loss but if there was a difference in power to turn either weight set-up.. Quote: �Tractor makers always recommend cast-iron ballast, but know that guys will use fluid��..Answ, there must be a reason for that! I understand where you are coming from on this issue but we aren�t comparing real world power losses that could be under 1%.. We were [are] discussing what weight package [assuming the same total weight] would take less [or more] horse power to turn & what set-up would be more efficient.. Clooney
