Yes, as posted below, it originally came from the factory wired Positive Ground, but many got changed over the years for one reason or the other or by accident. Also, if it were changed from pos to neg ground but the ammeters leads were not reversed, the ammeter would read bass ackwards. To see how its wired now, just see which Battery post is connected to frame ground, + or - To see if the ammeter is wired correct for what you now have, with the tractor not running, turn the lights on and it should swing to discharge. If it shows charge, either the tractor got ground converted or the ammater is wired wrong. Is it working and charging okay now????? ?? If not, post back or e mail me and I will send you or post a complete detailed troubleshootign procedure. If shes charging and the ammeter workign and wired right, she should indicate some charge, the battery voltage rise slightly and lights get somewhat brighter. If youre installing anything new, to be safe, I also suggest you polarize. Also, make sure the belt is tight and it or the pulleys not glazed and all connections are clean and tight. Post back or e mail [email protected] if you need more assistance. Best Wishes n God Bless John T Nordhoff
