JD 2510 Help Im Stuck !
matt
07-28-2004 03:05:15
Just purchased a 2510. Looks good, no leaks, and test drove fine. Problem now is that the gear shift lever is stuck in gear but the tractor will not move. The tractor will move if pulled or pushed like it is stuck in between gears. I cant move the shift lever at all. The tractor has the syncro range transmission. Tractor has about 5000 hours and everything else works great. Any ideas? Can't tell if problem is a transmission, shifter cam problem or if it is a control quadrant problem. Anyone know how to free it up?
Mike M
07-28-2004 10:40:58
 Re: JD 2510 Help Im Stuck ! in reply to matt, 07-28-2004 03:05:15
I would shut it off block the wheels to keep from rolling on you. Then unhook the linkage and see if you can get that Quadrant to work with nothing hooked up these do get sloppy and it may be bound up.
matt
07-29-2004 05:02:57
 Re: Re: JD 2510 Help Im Stuck ! in reply to Mike M, 07-28-2004 10:40:58
THANKS MIKE I'LL GIVE IT A TRY. SAY THE QUADRANT DOES FREE UP AND I HOOK THE LINKAGE BACK UP, WILL EVEYTHING BE IN TIME AND WHERE IT SHOULD BE GEAR WISE?
Mike M
07-29-2004 09:47:43
 Re: Re: Re: JD 2510 Help Im Stuck ! in reply to matt, 07-29-2004 05:02:57
I would think that it would be if it is just stuck and as long as you don't move any of the adjustments. If you get lucky and it was the quadrant just jambed up you may want to get some new bushings and build up some worn spots to help prevent it in the future.
