730 john deere diesel flywheel
marty
07-27-2004 20:53:07
Im working on a 730 jd diesel and fixing to replace the flywheel and I have'nt never traveled this road before.Any info or tips would be very helpful and appreciated.I've been told that there is timing marks on it but I cant find any and really dont know specificaly where to look.Again I would really be greatful of any info anybody might part with.Thanks
Clooney
07-28-2004 07:27:54
 Re: 730 john deere diesel flywheel in reply to marty, 07-27-2004 20:53:07
Marty, the flywheel replacement on the later 2-cylinder diesels isn't that bad of a job [much easier than the earlier diesels]..
~You should find marks on the flywheel hub & crankshaft stub that look like this ><, those marks must line up for the flywheel to be on correctly.. Sometimes the marks are obliterated due to hammering on the flywheel or crankshaft so in those cases either mark the crankshaft to match the #1 injector mark or TDC mark on the old flywheel then use that mark to install the new flywheel to. OR, turn the original flywheel so the flywheel slot is running directly fore/aft & the writing in one place then remove it & install the new flywheel with the slot & writing the same way..
The #1, #2 injector markings should be on the machined flywheel rim next to the ring gear teeth.. You might have use a Scotch pad to clean the area to see the small stamped writing..
The flywheel end play should be re-set to .005�-.010� when installing the new flywheel..
Be real sure to block the R/H end of the crankshaft ALL the way to the left [flywheel side] BEFORE pulling the old flywheel as there is a thrust washer inside the engine that can fall loose & get destroyed IF the crankshaft moves to the pulley side while removing or installing those flywheels.. That isn�t an easy job to replace that thrust washer so BE CAEREFUL not to move that crankshaft to the right while pushing the new flywheel back on..
A real good investment would probably be the I&T Deere 2-cylinder diesel service manual.. It�s a lot cheaper than the Deere diesel manual & really does a good job on the engines for those 2-cylinder diesels..
Any other questions just post back here..
[email protected]
buickanddeere
07-28-2004 06:05:17
Link
Tractor Manuals Special Offer: Purchase more than one manual and receive a free Serial Number Guide! [Main Menu] [General Info - FAQ]
Search for: Model:
Results of search for "720"
720 Diesel Service Manual (Aftermarket) 304 Pages (Part No: JD-201) $29.95
You need new bolts and a torque wrench too. Do a search for previous posting on this topic.
Mydeere
07-28-2004 06:02:46
I read your post regarding replacing the flywheel on your 730 but you didn't mention why you needed to replace it. You also don't mention what you are going to replace it with, a good used one or a taper loc. The general advice that I can give you is that you need to take a look at the crankshaft and determine if the splined end is worn, broken, missing splines, etc. If the crank is worn and you put a good used flywheel back on, you will more than likely end up with a loose flywheel. Now you can sometimes still use a worn crankshaft along with a taper loc flywheel with success. My recommendation would be to use the taper loc flywheel and be sure to tighten as tight as you can get it, run the tractor for a while and check the flywheel for tightness again. If you can give more info as to why you are replacing the flywheel or what you think the problem might be, I will try to help you further.
720Deere
07-28-2004 05:09:08
You should have an arrow on the end of the crankshaft and a mark on the edge of the flywheel hub that lines up with the arrow. That is critical as the crank and flywheel assembly are balanced together and of course injector pump timing cannot be correctly set or checked if the flywheel is out of position.
As to the timing marks, there should be marks on the outer edge of the flywheel for injector timing. They are located just outside of the starter ring gear. The marks should be such as "No. 1 INJ", "No. 1 BDC", "No. 2 INJ", etc.
720Deere
07-28-2004 07:31:14
 Re: Re: 730 john deere diesel flywheel in reply to 720Deere, 07-28-2004 05:09:08
Sorry, that should have been "TDC" not "BDC".
