J D 60 LP primer
Irv Plitzuweit
07-27-2004 18:01:11
My JD 60 LP had the solenoid removed that activates the "plunger" to allow gas into the carburetor. I intend to just manually push the plunger to allow gas into engine to help starting. So that no dirt or other objects get into this area I have place a rubber membrane over the open hole. This still allows me to push the plunger and one can hear the gas moving into the carb. MY QUESTION, do I have to vent this area, ie punch a small hole in the rubber membrane?
Thanks for any and all advice
buickanddeere
07-28-2004 10:45:25
 Re: J D 60 LP primer in reply to Irv Plitzuweit, 07-27-2004 18:01:11
I wondering if you are serious or one of those jokers who are home from school, bored and passing their time here making mischief? Purchase the proper electric solenoid. Before you burn down/blow up a building, the tractor, yourself and innocent bystanders with a "farmer fix".
