4020 three point won't lift
Mack
07-27-2004 16:40:22
Can anyone tell me what might be the problem why my three point quit working. The linkage works fine, but there is nothing when you lift the lever. The tractor is a 66 model and changing draft settings makes no difference. Thanks for any info.
thurlow
07-27-2004 22:11:33
 Re: 4020 three point won't lift in reply to Mack, 07-27-2004 16:40:22
Mack, there is a cam follower inside the rockshaft control valve housing (looks somewhat like a bobbin); sounds like it has come off track. Supposedly it can be put back on through access plug in rear of tractor. I've never had much luck; have always had to remove housing.
Mack
07-28-2004 00:08:20
 Re: Re: 4020 three point won't lift in reply to thurlow, 07-27-2004 22:11:33
Thanks for the help.
Dan
07-27-2004 19:51:50
How are other hydraulic functions, steering, brakes etc. If you have a remote plug you might try it also. These 3 points sometimes get out of adjustment and there is a series of adjustments, the final one being to adjust a bolt inside the housing, from the back with a long extension and socket securely taped on the end. If other functions are hampered it could also be a plugged filter. Did it just happen or has it been slowing down for a while? I used to work on these a lot but it has been a while.
Duane Larsen
07-27-2004 17:36:12
The tractor has to be running for the 3 point to work. You can't just move the lever and expect it to lift. Try starting the tractor first.
Yours Truly, Duane Larsen
P.S. If you need anymore help, feel free to email me at [email protected]
Mack
07-27-2004 18:09:15
 Re: Re: 4020 three point won't lift in reply to Duane Larsen, 07-27-2004 17:36:12
I wish my world was half as simple as the world you must live in. I hope nobody else has to waste time dealing with people like you.
Jon C -florida
07-27-2004 18:16:27
 Re: Re: Re: 4020 three point won't lift in reply to Mack, 07-27-2004 18:09:15
I agree with you Mack. The idiot that gave you such valuable advice is not Duane Larsen. (See my response a few posts down about the length of G spokes.)
Indydirtfarmer
07-27-2004 17:33:09
I bet you didn't even think to check to see if it's got oil? They don't work to well when you run em out of oil. Some people I swear... lol
John
Indydirtfarmer
07-28-2004 03:58:09
 Re: Re: 4020 three point won't lift in reply to Indydirtfarmer, 07-27-2004 17:33:09
This is the REAL Indydirtfarmer. The previous message WASN'T posted by me. It is someone using my screen name. (Check I.P. address if you don't believe me) I'm not that much of a smart a$$. Thanks. John
Mack
07-27-2004 18:27:29
I am sorry I did not check to see if the tractor was running or if there was any oil in it, or for that matter if that was the three point lever or the throttle that I was moving. If there is any knowledgable person out there who has had any experience with this problem I would really appreciate a reply. Thank you..
Jon C -florida
07-27-2004 18:35:19
 Re: Re: Re: 4020 three point won't lift in reply to Mack, 07-27-2004 18:27:29
Mack - The child is now impersonating Indydirtfarmer. Look at the IP address used in his moronic reply verses the real indydirtfarmer response on a post below. This started a week or so ago. Next he will sign things "mack" or "Jon C". This kid has got to go!
(Sorry I cant help with the 4020 question, but thought you should not blame Indydirtfarmer.)
john nelson
07-27-2004 19:58:24
 Re: Re: Re: Re: 4020 three point won't lift in reply to Jon C -florida, 07-27-2004 18:35:19
Mack, if it suddenly quit and the power steering still works, there is a priorty valve on the right side which could be stuck, also a drop speed control valve under the housing which it could be. Does the remote valves load the engine when you move them? The pump pressure goes to the cyl and the control is on the outlet or dump side of the valves. If you dont get working it i can scan and send you a pic of the mechanisim. There are several on here who know more abouit it than me, they may have more info.
John
Mack
07-27-2004 20:56:24
 Re: Re: Re: Re: Re: 4020 three point won't lift in reply to john nelson, 07-27-2004 19:58:24
Everything else seems to be working normally;steering,brakes,remotes,etc. Thanks for your input.
