4020 JD SN:
GT
01-31-2004 23:56:28
I purchased a 4020 today and in looking for the serial number, found a plate at the rear of the tractor that looks like a serial number. Is this the SN for the tractor or a number for the transmission/hydraulic system? Where can I find out the year it was built?
I drove this tractor a lot from 1968 to 1971. Then my father-in-law sold it at an auction. Happy to have it back. When I drove it I didn't pay any attention to when it was built or where the serial number was. Thanks for any info.
GT
02-01-2004 18:23:31
 Re: 4020 JD SN: in reply to GT, 01-31-2004 23:56:28
Thanks for the info on serial number explanation. Mine starts with SNT213P09..... I will check the 4020 website you suggested.
T213R
02-01-2004 06:40:57
The serial nimber plate on the 4020 is located above and a little to the right of the pto. You will see either a number beginning with 4020 (IF your tractor is a 1964) OR you will se a series of numbers that looks something like this: T213R195959R. The code sequence of "T213R" for example indicates a Diesel, rowcrop 4020 with syncrorange tranny. The "195959" of my example is the actual "serial number" but the "code" sequence is important also. Check out the explanation at forty-twenty.com for the full story on serial numbers.
Pete/ME
02-01-2004 03:32:46
That would be the serial number of the tractor. Starts with "SN" (for "Serial Number"...clever eh?). For more information try Forty-Twenty.com
GT
02-01-2004 18:17:08
 Re: Re: 4020 JD SN: in reply to Pete/ME, 02-01-2004 03:32:46
There is no "SN" prefix to the numbers on this tractor or if there was, it is not readable. Thanks for the info.
GT
02-01-2004 18:21:01
 Re: Re: Re: 4020 JD SN: in reply to GT, 02-01-2004 18:17:08
Whoops! I looked again and found what you described. I was looking for "SN:" preceding the numbers instead of SNT213P..... .. Thanks.
