Broken Stud
Dan
07-27-2004 10:24:14
I' Working on my 1950 D and came across a stud that has been broken. It holds the bracket that has the clutch lever and the throttle lever. The stud broke off even with the bracket so there is nothing sticking out past the bracket. Any suggestions on how to get the stud out and replace it?
Thanks
John T
07-27-2004 12:33:43
 Re: Broken Stud in reply to Dan, 07-27-2004 10:24:14
Dan, good advice there below, I will add my take on your question. Ive also had good luck by first welding a flat washer down over the broken stud. This prevents you from welding to the area immediately surrounding the stud and the center opening makes a decent bond washer to stud. Then you have a good area to weld a nut to against the washer plus a place to turn and the heat may help free her up.
When I do the drill n tap trick, I grind the surface down smooth so I can use a center punch and punch the dead center of the broken stud. Next, I use a small drill bit then progressively larger ones until I can drill her out then re tap.
When you have to weld in tight or difficult areas, a wire welder may be a lot easier to get a good start on.
Use patience, Good Luck n God Bless, let us know if you were able to drill her out or had to weld or whatever.
John T in Indiana [email protected]
Clooney
07-27-2004 11:34:33
Dan, both Jon C & Bent gave you good advise..
~If that bolt is broken off even with the bracket you might try removing the other bolts then pulling the bracket out & away from the case,, that should leave some of the broken stud exposed so you can heat it then use vise grips to remove it..
~If you can�t get that bracket out of the way then you might have a hard time welding on that stud� If I were doing it I would use a L/H drill bit after using a smaller drill bit to start a good centered hole.. With luck the L/H drill bit will heat the stud while drilling then catch on it enough to turn it out while drilling.. Once removed chase the hole threads with a good tap..
[email protected]
Jon C - Florida
07-27-2004 10:47:39
Couple of ideas to try:
1. Left handed dirll, and drill it out.
2. Weld on a flat washer to the stud, and then a nut on the flat washer. The heat of welding, and the nut allowing you to put a wrench on it should do it.
3. I don't care for drilling a hole in it and using "easy outs", which are inappropriately named, since they are anything but. If you want to try that, use a square shanked screw extractor.
4. If no. 2 above doesn't work, add a lot of heat to the bracket until its CHERRY red, and then hopefully it will squeek out using a screw extractor or the nut that you welded on.
Bent
07-27-2004 10:42:07
Dan, I have tried everything to remove broken studs, from easy-outs to left handed drill bits. If you have any of these, take them and walk to the nearest bush, and throw them as hard and far as you can.
I weld a nut onto the broken stud and use penetrating fluid called "mooovit". Works every time. Takes some practice but life is too short to mess around with broken easy outs.
Brent
Bob
07-27-2004 14:02:38
 Re: Re: Broken Stud in reply to Bent, 07-27-2004 10:42:07
Bent,
Like I always say "easy outs aren't"!
Welding a washer or a nut onto the broken stud not only provides something to grip, but thermal "shock" helps to break the stud loose. I use as much heat as possible, and linger on the stud with the welding rod as long as possible, to heat the bolt untill the nut or washer is ready to melt, and then let the whole thing cool to ambient, put some PB Blaster on it, allow it to soak in a while. Many times, the stud will turn right out. If it does not, repeat the procedure.
bent
07-28-2004 08:38:00
 Re: Re: Re: Broken Stud in reply to Bob, 07-27-2004 14:02:38
Bob, I forgot to mention washer, never use to use one until I welded outside the broken stud.
If you can get some Mooovit, you will be tossing that PB Blaster as far as the easy outs. I guarantee it. Example, 55 year old exhaust manifold studs came out, 1 after day one, the other after day two. No heat.
Brent
