4020 hours
Chuck
07-27-2004 07:06:13
Guys,
Am a farmall guy but looking at a 3020 and a 4020. I have fourty ac that I lease to farmer but would like to farm myself some day. My question is? The 4020 is a 67 has been repainted and has around 8500 hours on it. It has a diesel motor. Is this a lot of hours. The guy is asking $9800. Dont see any leaks any where but like I said the tractor has been repainted. Tires look good. Front weather checked but not bad. The guy selling the 4020 is the person that sold me my land. So I know him but not real well.
The 3020 is going for $8000. Not sure of the year but it has oil on it every where there is a hyd outlet. This tractor has around 5500 hours on it and is also a diesl. Stoped to look at this one for sale on road side. Dont know the owner. Tires look good. Have not heard either tractor run. Both have three point.
Would like to hear any pros or cons on both tractors. I presently have a 52 farmall H and a 73 MF 135. Just growing deer food plots right now on ten ac to get a little experince.
Bill(Wis)
07-27-2004 17:36:54
 Re: 4020 hours in reply to Chuck, 07-27-2004 07:06:13
Chuck: A good place to window shop and see a lot of tractors in a hurry is on the John Deere website. Machine Finder. Just ask for 3020's & 4020's and you'll see hundreds of them.
chuck
07-27-2004 11:32:46
Thanks for all the info. Just to let you know the tractors are in southeast michigan. Where tractors prices seem to be high because of all of the hobby farmers(like me)
thurlow
07-27-2004 11:18:11
I guess I'm in disagreement with some of the guys below about the 4020; 8500 hrs is not a lot of hours for a 35-37 year old tractor. Even if the engine is original.....not overhauled; if it's been well-maintained, you could expect many more years out of it, given your expected usage. As to price, it would bring $6000-7500 in my part of the country; depends on the market where you are.
Greg H.
07-27-2004 10:08:56
Chuck,
A 4020 or 3020 would be a good hay making tractor. Ask the owner what all has been done on the 4020. If you think you are going to do any tillage work the 4020 might be alittle nicer. 9,800 is allot of hours on a tractor that hasn't been rebuilt. However if you buy one of these tractors and keep it maintained it will last along time. My 4020 is a very good tractor, and it's ready to roll over 5,000 hours. My father in law's 1964 3020 has been rebuilt twice, and is over 15,000. Just make sure you check your trasmission linkages, and clutch, and if your hydrolics work fine. The nice thing about either tractor is that if they do need rebuilt, you can replace about everything in the engine for 1500-2000 dollars, and be ready for another 5000 hours. Good Luck.
Jason Z in MO
07-27-2004 10:07:42
I looked at the pictures on your web site. Looks like you have the 135 cleaned up nicely!
I have a couple of 4020's and really like them. I don't know enough about the longevity of the engine to comment on the hours. I can tell you what I know...
From your pictures the 4020 is a syncro range with a single hydraulic remote. If you plan to use this tractor for planting, running a batwing bushhog, round baling, etc. the second remote would be a must. If you need one, I have found all the used parts to add it to mine for $500.
It does have set of front weights.
From the picture of the dash, the 3 point lever is in the raised position but the drag links are hanging down. Either the cylinder isn't holding after the engine is shutdown or someone moved the lever after the engine was shutdown. Might want to check on that.
Might want to find out how many hours on the clutch.
The load control shafts leaking trans/hydraulic oil are a common problem. You can easily see if they are leaking. Look around the lowest point directly under the seat. Not hard to fix but can be a "dickering" point.
The PTO shield and Top link is missing... (Might have been removed to prevent them from being stolen.)
Hope this helps you get the price down!
Jason
matthew
07-27-2004 09:43:49
check the bolts to see if paint is missing. this will tell you if the tractor has been split. even with the best care the 4020 is probably needing to be spit and at least some work done. now thatts not always the case but most at that many hours will need some work. good luck
Del
07-27-2004 09:10:02
A 4020 with 8500hrs or a 3020 with 5500hrs should have a lot of life left in them if they haven't been mistreated. A good overhaul would help them and do them some good. A big plus for those tractors is I've never heard of someone needing to replace or reprogram a computer on them.
Hayfarmer
07-27-2004 07:21:09
the 3020 and 4020 are both great tractors if taken care of. The hours on the 4020 are high if it has not been overhauled at some point. Usually they see an engine overhaul at around 6500 hours. You don't mention options. Both tractors were available with synchro range or powershift transmission. They were also both available with differential lock. Power shift usually goes for a bit more. I have seen a number of adds for 4020s for the 10,000 range but usually they are in excellent shape. Most of the 3020s I have seen go for around 4500 to 6000 especially in the condition you mention. Price depends upon the are you live, sometimes a painted tractor can be deceptive as it looks good to cover up some problems. 4020 is rated at 96 hp where as the 3020 is about 85 I believe.
Ralph
07-27-2004 07:26:18
 Re: Re: 4020 hours in reply to Hayfarmer, 07-27-2004 07:21:09
3020 is 4/6 of 96 or about 64 HP, 4 cyl vs 6 cyl.
