Coolney Torque Spec
Woody
07-26-2004 15:18:51
Coolney Torque Spec
I have a "IT" manual and just has a torque for the cylinder head? Was there not any torque spec for the rods and main bearing caps? This on a John Deere "B" serial 201000 and up Gas. Any help would be great. CjW
Clooney
07-26-2004 17:26:17
 Re: Coolney Torque Spec in reply to Woody, 07-26-2004 15:18:51
Woody, Deere wasn't to forthcoming on many torque specs back in the letter series days & the ones they did give weren't for those adjustable main bearing bolt nuts.. You can't even use the standard bolt torque spec for that sized bolt as you are crushing a stack of brass shims.. There might be a spec listed in a service bulletin but I couldn�t find one with a quick look.. I never torque those bolts but just get them fairly tight & so the cotter pin hole lines up. If you over-tighten those nuts the main bearing(s) might end up too tight so check the crankshaft for free rotation after the nuts are tight.. The rod torque specs for that 201000 and up �B is listed in a Deere service bulletin & that is @ 63� lbs..
Cylinder block to main case = 125� lbs
[email protected]
Woody
07-26-2004 17:42:47
 Re: Re: Coolney Torque Spec in reply to Clooney , 07-26-2004 17:26:17
Thanks Clooney that helps. CjW
