2040 and 145ldr
Tony
01-31-2004 19:17:16
I just bought this 2040 and 145 loader and noticed the bucket dumping cylinder sometimes stops about halfway through its' cycle and will then sometimes proceed all the way over and sometimes not. When it stops midway, the hydraulics make a snapping noise and the front wheels make a little jerk when the lever is reactivated. There is a little bit of jerky motion at times on the movements of the bucket and boom, but not much and mostly at low rpm. Also, there seems to be no "float" ability if you push the boom lever forward fully. I thought this was to allow the weight of the loader to float along the ground. I checked the fluid and it seems normal level and clear. I can't get the shift lever to engage the park position either and the manual shows this unit to have a park position just above range II. Any help would be great.
Brokenwrench
02-01-2004 05:12:33
 Re: 2040 and 145ldr in reply to Tony, 01-31-2004 19:17:16
The clutch must be out (engaged) for proper hydraulic function. There is a pump in the rear end that pumps oil to the main(front) pump. If you sit with the clutch in,the pump in the rear doesn't pump,and you lose function as the front pump loses charge oil pressure.
To engage park, you must put the right hand shifter in 1st gear,before you engage park on the left shifter.
Tony
02-01-2004 11:51:38
 Re: Re: 2040 and 145ldr in reply to Brokenwrench, 02-01-2004 05:12:33
Thanks much!
David
01-31-2004 20:50:32
As for the park problem, try putting it in first gear before setting the park.
