JD 530 Steering Wheel Removal
GP
07-26-2004 08:41:39
I am replacing the steering wheel on my 530 with power steering. I got the nut off, now how the heck does the wheel come off the shaft?? Do I need a puller? I don't care what happens to the wheel as I am replacing it anyway, but I don't want to hurt the shaft. Thanks for any help.
Larry L. Goodwin
07-26-2004 12:25:50
 Re: JD 530 Steering Wheel Removal in reply to GP, 07-26-2004 08:41:39
I may be in the minority here but I sure would NOT use heat on that plastic steering wheel especially if you aren't sure what you are doing. Use some penetrating fluid, then use a bar type puller. I have never had any problems getting them off that way.
JLC
07-26-2004 12:11:44
GP
We just took a steering wheel off a 530. The wheel is on a splined shaft. Remove the center cap it just prizes off then use a steering wheel puller to remove the steering wheel. You may have to put a little penitration oil on the shaft to loosen the rust around the splines. Good luck.
ia dean
07-26-2004 21:03:52
 Re: Re: JD 530 Steering Wheel Removal in reply to JLC, 07-26-2004 12:11:44
First clean the two 5/16 tapped holes in the steel hub with a tap. Cut a 2-3/4 long x 5/16 thick x 3/4 wide flat strap. Drill two 11/16 holes centered on 1-3/8. Lay strap inside wheel hub against shaft , start two 5/16 x 1 1/4 hard steel bolts, tighten down and walala she's off.No heat, no hammer no damage! Label puller and store with poppin johnie stuff for future use!
TIMAR
07-26-2004 11:14:21
Heat the hub of the steering wheel around the shaft. While it is hot, hit it with a hammer. Has never failed me yet.
