Greg, if youre sure??? its not getting into the oil from a leaky carb as you indicate, heres a few other possibilities. If you leave the carbs bottom drain cock/plug open and turn the fuel off shes not dripping any gas out right??? Some old tractors eventually accumulate a bit of gas in the crankcase due to general wear and age BUT ESPECIALLY IF THE SPARK IS WEAK OR OVER RICH RUNNING. 1) Is the tractor running rich??? Is there excess black smoke out the exhaust stack??? If so, try leaning the carbs top needles a tad and see if the exhaust cleans up (black smoke free). The initial carb rough in settings are about 1 turn out for the load needle and 2 out for the idle. 2) Make sure the choke butterfly plate is opening fully and staying open?? If not, she can run rich and eventually leave some gas in the oil. She can gas foul the plugs (flat black colored sooty coat), not combust the fuel so well which adds to the problem of excess unburned fuel. 3) Is the air inlet pipe, the air cleaner bowl, and the air cleaner mesh all clean n restriction free?? If not, she can run rich, add gas to the oil, and same as above. 4) Is the spark good?? Remove both plugs but have their wires attached and sides grounded, turn her on n crank her over and insure both plugs produce a good visible BLUE and NOT a faint thin wimpy yellow spark. If so, post back what ignition you have for spark troubleshootign tips. 5) Is she fouling plugs often??? If so are they that flat black colored sooty looking?? If so, check the spark per the above. Use wire core and NOT carbon core wires. 6) Is she an oil burner?? Is there excess blue smoke out the stack and/or excess crankcase blow by?? If so check the compression on both cylinders. 7) What shut down proceure are you using?? I like to shut the gas off and let her idle n die from gas starvation. YOURE NOT CHOKING TO KILL HER RIGHT?? If so, that can add gas to the oil. If its not too bad, a good general tune up and oil change, fresh maybe hotter (388 Autolite) plugs, setting the carb correct, checkign the valve lash settings, and insurign no choke or inlet air restrictions may help. Let us know about any over rich or black or blue smoke, your spark quality, and what inition you have. PS I believe some A's had the pushrod tubes others did not, if shes parked downhill in front end and the valve covers removed, you may see water trikling down them. Good luck n God Bless John T in Indiana
