2840 likes ether
Pete
07-26-2004 05:45:48
It's getting so our 2840 likes ether even when it's warm out side. The tractor has the same amount of power as it always has and doesn't use oil. What would cause this? It seem crazy that you have to give it a spray of ether when it's 60 degrees out.
mitch
07-29-2004 07:06:00
 Re: 2840 likes ether in reply to Pete, 07-26-2004 05:45:48
its addicted to it, and it will only get worse. my uncles neighbor had a 4440 that had to have ether when it was 90 outside. the more you spray it the more it wants it. the answer is a motor rebuild and after you do that NEVER SPRAY ETHER
david val
07-27-2004 00:51:10
on borderline cases,adjusting the max fuel setting to it's upper limit may help.
david
buickanddeere
07-26-2004 08:35:08
Cranking speed could be slow? What is the voltage measured from the starter's case to the starter's heavy post that is only live when cranking?
Try the old classic steering wheel wiggle when cranking. Low cetane fuel?
Tired injectors?
Injection timing too early or too late?
What is the compression pressure?
Somebody may have detonated the top rings into pieces and/or ruined the piston ring lands with ether.
Pete
07-26-2004 09:26:58
 Re: Re: 2840 likes ether in reply to buickanddeere, 07-26-2004 08:35:08
It only does it on the first start of the day. Once the engine has been ran it starts fine on it's own.
buickanddeere
07-26-2004 11:41:11
 Re: Re: Re: 2840 likes ether in reply to Pete, 07-26-2004 09:26:58
Could still be suffering some of the above listed problems. The diesel fuel sprayed into the combustion chamber needs heat to fire. An pre lubed engine with an internal temp of 150-200F and pre-warmed intake air and freshly topped up batteries. Is all together different animal than an 50F engine/air .
New-Gen
07-26-2004 07:53:31
Don is right, but if it has good power and doesn't use oil I'd just run it. You can buy a lot of ether for the price of an overhaul.
DON
07-26-2004 06:25:37
COMPRESSION IS LOW, NOTHING A SET OF SLEEVES AND PISTONS WONT CURE. SORRY, DON
Pete
07-26-2004 09:30:48
 Re: Re: 2840 likes ether in reply to DON, 07-26-2004 06:25:37
Do you know what the compression should be?? Where do you test the compression on a diesel?? I have compression tested many gas engines before ,but ever a diesel.
Lloyd ( in CT)
07-26-2004 13:06:33
 Re: Re: Re: 2840 likes ether in reply to Pete, 07-26-2004 09:30:48
You will need a special diesel compression tester for the hi compression, You might want to look at rebuilding the injectors or injection timing first.how many hours on the tractor
Pete
07-27-2004 08:23:05
 Re: Re: Re: Re: 2840 likes ether in reply to Lloyd ( in CT), 07-26-2004 13:06:33
The tractor has 5010 hours..... It had a rebiult injector pump put on 2 years ago.
