J D 2010 hydraulics
Don
07-25-2004 20:25:34
Considering buying a JD 2010 diesel.hydraulic arms on three pt. will not go up or down when hydraulics are engaged. Motor is under strain as pump is engaged but nothing happens. Only movement of hydraulic arms is when the motor is initially started. They go up on their own. a New hydraulic pump has been recently installed. Anyone have any ideas on problem, I would appreciate help. Don
Joe Stewart
07-26-2004 14:38:42
 Re: J D 2010 hydraulics in reply to Don, 07-25-2004 20:25:34
Do you know if the hydraulic filter was replaced at the same time that the pump was replaced? Those wire mesh filters become clogged with microparticles and no amount of cleaning seems to help them. If the filter was not replaced, the first thing I would do is buy a new one from John Deere ($60) and install it and see what happens. It could be that simple, but if that doesn't fix it, then you're getting above my head (?stuck valve somewhere?). The fact that it tries to lift on initial start-up and then becomes strained supports the idea of a clogged filter, I feel. Let us know what ultimately corrects the problem. Joe Stewart
Don
07-26-2004 17:34:20
 Re: Re: J D 2010 hydraulics in reply to Joe Stewart, 07-26-2004 14:38:42
If I understand correctly there is a lever under the seat that might possible be set wrong(if so what is the correct position)and also there is a linkage on the left side below the floorboard(actually ahead and below the clutch pedal) with a spring and a flat bar on it going nowhere looks like it might be inline with the hydraulic pump. I understand this has a correct position also (any ideas on where to set it) .The guy that owns it never in 7 years had a reason to use the 3 pt system as all he ever did was pull a dragger mower.He replaced the hydraulic pump last year because the pto got to where it wouldnt turn he said this fixed the pto problem. I assume the power steering ,pto and hydraulic arms all work from the same pump. Would appreciate help on correct settings.Thanks Don
Joe Stewart
07-27-2004 15:40:47
 Re: Re: Re: J D 2010 hydraulics in reply to Don, 07-26-2004 17:34:20
Don, Does your power steering work and if so, does it work well? That little lever with the spring and flat bar disengages the hydraulic pump. The spring holds it in the "engaged" position, which is where you should have it if you want hydralic pressure. The lever(s) on either side and under the seat are load and depth control and should not prevent hydraulic pressure from reaching your 3-point. I'm a little puzzled by the previous owner associating function of the hydraulic pump with proper functioning of the PTO, since the PTO runs off of gears, not hydraulic pressure. Power steering and the 3-point are dependent upon proper functioning of the hydraulic pump. I guess one easy thing for you to do is to hook up a pressure gauge (use one with a 1500 or 2000 psi max) to the test port - you'll have to remove the seat and take off a little plate to get to it and measure the pressure that the hydraulic pump is putting out and follow the algorithm in the service manual. Good luck. Joe Stewart
Don
07-27-2004 16:25:01
 Re: Re: Re: Re: J D 2010 hydraulics in reply to Joe Stewart, 07-27-2004 15:40:47
Joe thanks for your time and trouble on this problem.The power steering is great!There are two levers on the left side of steering wheel outside lever is locked up stuck other lever when moved to up or down throws a load on the engine .Be real honest not sure which lever operates hydraulic arms.I am glad to know about the pto not being hydraulicly driven.Joe at any rate with a new pump working what am I looking at worst case possible .If I get the manuals I think I can do the labor money wise how deep can this get beyond the screen and the new filter. I drove the tractor sounded very solid(engine didnt have the forty year rattle when started cold) Zero grind or failure to shift in any gear.For the sale price of 1500.00 I think I could put a few bucks in it and still be ahead.Appreciate your reply Don
Rick
07-27-2004 18:07:00
 Re: Re: Re: Re: Re: J D 2010 hydraulics in reply to Don, 07-27-2004 16:25:01
Don,
If I understand the conversation right I may be able to supply some info from my manual. The levers on the left according to my manual are as follows: 1. outside lever furthest from steering wheel is the remote hydraulic cylinder control lever (essentially the auxillary hydraulic control for the rear hydraulics mounted behind the seat. 2. The inside lever is the rockshaft control lever (what this is used for I have no idea). To move the three point hitch on mine I use the lever to the right of the seat.
If we can pinpoint what part of the manual you need I could fax or scan & e-mail to you.
Rick
Don
07-27-2004 19:06:30
 Re: Re: Re: Re: Re: Re: J D 2010 hydraulics in reply to Rick, 07-27-2004 18:07:00
As I crawl up on the keyboard to type now(From feeling so small, obviously I,ve been given to much credit)Rick I certainly hope your right about the hydraulic arm lever being on the right side of the seat I feel so stupid at this point.I was raised in the seat of an 830 I should have remembered. Thanks Again. Don
I cant wait for the sun to come up tommorrow so I can go see if it works HAHA!
Don
07-27-2004 18:27:45
Rick, if I'm following you then neither lever to the left of steering wheel operates the hydraulic arms on 3 pt correct. You also say your is to the right of the seat didnt anything jump out at me(obviously) like there was another lever for the arms under the seat maybe HUH! Never looked on right side of seat I know there is a lever on the under side of the seat on the left side but thought it was seat adjustment.Any kind of view would be appreciated Thanks Don
Joe Stewart
07-28-2004 11:34:34
 Re: Re: Re: Re: Re: Re: Re: J D 2010 hydraulics in reply to Don, 07-27-2004 18:27:45
The cable for the 3-point on my 2010 (a row crop model) goes from one of the levers to the left of the steering column, under the floor plate and terminates on a small lever on the right hand side of the rockshaft housing. I am assuming that you have a utility model, which apparently is different. I am glad to hear you have found the problem. You might try some of the larger tractor bone yards to find that cable. I have purchased from Worthington Ag in the past. Joe Stewart
Don
08-01-2004 07:50:42
 Re: Re: Re: Re: Re: Re: Re: Re: J D 2010 hydraulic in reply to Joe Stewart, 07-28-2004 11:34:34
Getting close the lever on the left hand side of the steering wheel closest to the steering wheel is cable operated looks like it goes to a lever on the right side of tractor below the seat this lever will not budge .I would like to know if I could test the hydraulic arms by starting tractor and disconnecting the cable and try to operate the lever manuelly.With the arms coming up automaticaly when the tractor is started tells me there is something working on the hydraulic arms.
don
07-28-2004 10:29:11
I think I have solved part of the mystery as to why the hydraulic arms dont work THERE IS NOT A LEVER TO OPERATE THEM ! Dealer tells me there is a cable coming from under seat to a lever on the right hand side of seat NODDA! So next question is why not .I suppose it can be operated to see if they will lift if I take the seat off and operate manually .Then start the Easter Egg hunt for the original stuff to make it right any ideas on were to start.JD said good luck on finding the parts.
